AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Pioneer VSX-1021 Owners' Thread
Pioneer VSX-1021 Owners' Thread - Page 21
post #601 of 2597
Additionally, the reason for the change is to position myself for an eventual upgrade to a newer tv. The price for the vsx1021 at Amazon was too good to pass up,
post #602 of 2597
Hello I just purchased by brand new Pioneer VSX-1021k a few days ago. Unfortunately I am having a serious issue with the unit. When I first power on the receiver it does not play any sound through the speakers for about 5 minutes and then it will magically begin......after changing no settings. It is really sort of creepy.
This happens with any source. I have my DVR, PS3, and Xbox 360 all wired in using HDMI cables. When either of those sources are on, and selected on the receiver after just powering it on, there will be no sound coming from any of the speakers for about 5 minutes. The video works fine immediately however. Once the receiver "warms up", the sound comes on and I can flip through HDMI input with out any issues and everything seems normal.
The only time this does not happen is if I have had the unit on for a few hours, turn it off, and then turn it back on within the immediate future. Where as if I turn the unit off before I go to sleep and then turn on in the morning it will have the no sound issue. That tells me that it needs to "warm up" first.
Is this plausible? Has any body else experienced this issue? Do I have to keep this thing on ALL the time? Do I have a defective receiver? If this is normal I definitely will not be keeping it and will most likely switch over to the Denon.
Please help!
post #603 of 2597
My receiver is showing a blinking message that says "UE33". I can't figure out what the problem is. I was messing with my Ethernet connection...any help is appreciated.
post #604 of 2597
I know how to fix this. I had the same issue.
The amp is trying to download the new firmware, and is unable to.
What I did is go to the pioneer website, downloaded the firmware, put it on a USB flash drive, put it in the usb port at the front of the amp.
Then you go to the setup menu where you update the firmware, and you can select via usb. And it updates, and you wont get that error any more.
I found that error was also causing issues with the network setup of the device.
post #605 of 2597
Originally Posted by robinavs View Post
I have an HD cable box (Cox) that uses the input hdmi 1 on the receiver. Everything works well... sound and video. My question is what if I just want to watch tv w/o turning on the receiver? I get no sound or picture. Would I have to run an extra cable from the cable box to my tv?
setup:
lcd tv hdmi
cable box hdmi
bluray hdmi
1021 reciever
The way I solved this was to run a component video and audio cable from the HD cable box directly to my TV. (I also have an HDMI cable from the HD Cable box to the AVR). All I have to do is select my video source on my TV to Component video and it's like the receiver isn't there. When I want to hear surround sound for a movie on tv or Bluray, then I just change the video source on my tv back to the receiver.
It appears that the audio and video will pass thru when the receiver is in standby mode only if your component supports HDMI control (pp. 43-45 in the manual). My TV supports HDMI Control, but not my Motorola DCH3200 cable box, therefore no audio or video when the AVR is off.
Why does it seem the industries don't communicate when making sure most components work together? Or am I missing something?
post #606 of 2597
Hi
I love my new 1021k; it's been a clear step up since I replaced my Yamaha a few months back. Everything seems to have be working (touch wood) but for some reason the unit does not recognize my hd streamer/ media player.
When I connect my egreat r1b to the unit using hdmi, I get an unstable picture with a weird green screen alongside with constant flicker.. The player connects to my plasma effortlessly giving me a stable picture.
Clearly a problem with compatibility- any ideas? Thanks a ton...
post #607 of 2597
Originally Posted by bennysoultrain View Post
I just set my receiver up and am having the same problem. It's annoying because one of the reasons I bought this was so that I no longer had to connect my first generation Airport Express to stream to my living room stereo. I'm connected via Ethernet. My Mac is only two rooms over and I'm unable to play in both rooms at the same time because the delay is too noticeable.
I'm surprised nobody else is brining this up. This is driving me crazy. My old Airport Express synched exactly with my mac and receiver. If I was at my computer - I could hear the sparkers in the other room and all was good. Airplay for this receiver is not synched. It's of a fraction of a second off but - in a small house - enough to make my setup of receiver and computer speakers for full house sound unusable. This has got to be a Pioneer problem, right? If Airport Express - connected via one simple cable (I've got the old version - not the digital one) - synched exactly, why can't the Pioneer?
post #608 of 2597
Yeah! This upsets me very much. I am starting to think that our units are faulty since no one else seem to have this problem. Could someone please confirm that this indeed works in their setup? I mean this must be one of the most common use cases for this receiver. Stream music from Mac with airplay/arirfoil, listen to audio in both mac and receiver simultaneously.
When I do this the delay of output sound in the VSX-1021 is not long, but to long to render the setup usable. I use a Windows HTPC as receiver instead of the receiver now. I have also tried to use iPad/iPhone as Airplay/Airfoil receiver and the sound is in perfect sync with these.
post #609 of 2597
Please help!
Earlier in this thread someone else had the same problem. It's a faulty relay in the receiver. Exchange it.
Alright. A certain online vender has a sale on the 1021 this weekend and I had two questions before I purchase it.
1. How does it work with only three front speakers and a sub attached? I won't want to run rear speakers initially. Will it shunt the rear audio through the front or will it drop it?
2. How does it work with no speakers? In other words if I can't buy my speaker kit for another month can I just use it as a HDMI switch for the time being and still have audio come out the TV?
post #610 of 2597
I don't know we're looking same website, those prices too good to be true I couldnt believe my eyes , I really don't need second unit, but I will get it anyway.
1- No problem with 3.1 systems, I'm using it right now. You can add more speakers later. Just run the MACC that will detect front 3 and the sub.
2 -I don't see any problem with that. If you can, use any bookshelf speaker as center, it's still better than TV's speaker
post #611 of 2597
Anyone with experience of using the system with a media player/ media streamer/ etc - like Roku/ PlayOn/ Xtreamer/ eGreat/etc - would be good to know your experience with this unit..
post #612 of 2597
Has anyone seen any news about Pio updating the firmware/airplay build to matchup with what is available via Apple TV and iOS 5? I tried it the other night and it didn't work-tried it with my apple TV after the ios 5 update and it does work.
After seeing how fast this went on sale after the iOS 5 launch, am thinking no. The aTV has way more processing power than whatever chip Pio put in the unit to enable/manage airplay. Would be nice if they could update.
Airplay mirroring is one the coolest features ever. Real Racing 2 HD on the ipad gives a near original Xbox level gaming feel. And its likely to get better.
post #613 of 2597
The VSX-1021 does not support Video over Airplay. I would be surprised if it ever will...but we can always keep our fingers crossed
post #614 of 2597
Originally Posted by ZXSpeccy View Post
No zone 2 AirPlay or HMG on zone 2.
I think it's been evident by the responses here that this is untrue.
Originally Posted by ace1281 View Post
Im not having any luck with hdmi pass through and about to give up on it and just use the amp every time I use the tv. My question is how much electricity does the amp use if I have the volume half way using a 5.1 system. Is it similar to leaving four 55 watt light bulbs on while I watch tv?
I've been keeping track of my system's power usage recently, but not the receiver specifically. I noticed today that with my setup playing via Airplay in a 3.0 setup around -14dB, it was squeezing out 280-300watts, but that's with my other components (ATV2, LED TV, 2 subs, PS3) connected and powered off. I'm not inclined to dig into my cabinet just to separate the receiver's power cord, but I can give you a roundabout estimate comparing whatever setup you want vs all components powered off.
Originally Posted by meledward View Post
AIRPLAY - Issue - Question
Main Configuration
DSLMOdem -> switch Hub -> wireless Router
Computer and Ipod run off wireless router.
Reciever runs off Switch Hub.
Ipod can control the receiver just fine.
But I can not get airplay to find the receiver. If I move the receiver to the wireless router then it will be found by airplay.
The receiver gets Ip Address of 192.168.2.11 if on switch hub, and 192.168.2.12 if on the wireless router.
So, is this an airplay limitation or perhaps a forwarding/configuration issue on the wireless router?
Can you manually configure airplay to look at an address for a device?
This could depend if it's a switch or a hub as someone else mentioned. I'm not sure if AirPlay would work if you have a 10/100/half segement of the network.
My first troubleshooting step when AirPlay acts up is to forcibly close the music app. Next would be to cycle power on the receiver, followed by power cycling the router. This has worked every time for me.
Originally Posted by AlexSing View Post
Can someone answer this for me too, how do you get music out of all speakers?
If your source is just 2-channel, you'll have to change the listening mode to a surround mode that replicates the sound to the other channels.
Originally Posted by ajadudu View Post
I am trying to get this setup, someone mentioned it is possible but I just can't get this to work.
This is what I setup:
System Setup -> Manual SP -> Speaker system -> Speaker B:
With this I get
a) No volume control capability (i.e. mute)
b) 7.1 speakers working. However, back surround plays what is playing in zone2. Switch off zone1 and back to speakers still work. Change zone2 source and 5.1 speakers playing zone1 source, other 2 rear speakers play something else. No good.
System Setup -> Manual SP -> Speaker system -> Zone 2:
a) Volume control capability (i.e. mute)
b) 5.1 Speakers working
c) Zone 2 does not play in zone 1(obvious as the two rear speakers are disabled).
Does anyone have a way around this?
I want to be able to have 7.1 in zone1, control the volume in both zones independently and not have zone 2 'bleed' into zone1 via the rear speakers in zone1.
Thanks!!
Originally Posted by George33027 View Post
My opinion is that you can only have 7.1 OR 5.1 plus zone 2 OR 5.1 plus speaker B.
Depending on your rear connections, the zone 2 needs to be in the zone 2 connections, OR for speaker B the speaker B connections.
The stereo for either B or Zone 2 comes from the 7.1.
Keep re-reading the manual for speaker configurations.
Then follow up in the set-up.
+1
Originally Posted by J Zeilinger View Post
Thinking of buying this unit. I have a 10 year old Pioneer Elite tv with Component in (1080i).
Will this receiver (VSX-1021) allow my HDMI 1080p sources to be output via component to the TV?
I'm asking because i am now returning an ONKYO NR609 which does not. On this Onkyo, only component sources can be output via component. Seems crazy to me and want to confirm the Pioneer does what i need it to.
The receiver will not down-convert digital HDMI signals. Nothing out of the ordinary there.
A note about Apple TV... I've recently run into issues where I received the error message that my connection doesn't support HDCP. I seemed to have fixed this by switching the ATV to the Video 1 input rather than the first 'Assignable' input. Just a heads up that all HDMI inputs might not pass this signaling.
post #615 of 2597
Does anyone notice that the 1021 does not seem to remember the last audio settings?
I have mine set to ALC when on the DVR. Turn it off and the next day when viewing I check the audio and it is not set to ALC, and have to change it.
My VSX 826 remembered all the audio settings for each input.
Is there a setting that I missed?
post #616 of 2597
I have my xbox connected via HDMI (as is my PS3, DVR) - sometimes I get 5.1 out of the receiver and others it's just Stereo. Tested every time just on the xbox dashboard. The settings are correct in xbox systems settings, to output digital 5.1. Any idea why sometimes it will choose 5.1 on the dashboard and other times it will go Stereo?
Thought it might just be because there was no 5.1 signal, so I started up a game that plays in 5.1 - the receiver still didn't switch to 5.1. Is there a way to force it?
Edit: Solution is to disable Display Detection in Settings -> diisplay menu in Xbox. Simple as that. At least worked for me. Connection is Xbox -> Receiver -> TV -- via HDMI.
Edit 2: solution above ended up not sticking. Turned everything back on a few hrs later and Xbox is back to Stereo. Pain in the a$$. Will try going optical audio I guess.
post #617 of 2597
Just got a VSX-1021-K from newegg, and installed it last night.
I notice that when streaming movies though my PS3 slim, the front display panel reads "PCM". Is there a setting so that it will display the source (i.e. BluRay) instead of the audio format (PCM)?
post #618 of 2597
I was able to easily change mine using the iPad app under "settings". You can also rename inputs using the receiver's remote control though. I believe when you press the 'Home Menu' key, one of the options is 'Input Setup'. From there you should be able to scroll through the inputs and rename/disable them. I was able to fit "PlayStation 3" into the input name for mine successfully, and display that on the receiver's screen.
post #619 of 2597
Thanks, but that's not what I was asking.
I have also been able to customize the name of the source inputs directly with the remote control. (Don't need an iPad to do this.)
However, when I'm using the receiver, it shows the name of the audio format (for example, PCM, Dolby Pro Logic, DTS) that is being played. I would like to change it so that the display panel shows the source input instead (for example: Bluray, Playstation 3, DVR, TV/DBS). Is there a way to do this?
post #620 of 2597
Ahh... gotcha. I'll have to fiddle with mine when I get home and see what I can come up with since I don't have a manual with me.
post #621 of 2597
This is directly related to what I came in here to ask! I just got my 1021 today, I'm in the process of ordering a sub, front left/right, and center speakers. I have my FiOS DVR, PS3, and Apple TV hooked up to the device via HDMI, however, I cannot get any sound to play through the TV itself. Obviously this is just to hold me over until I get the speakers - but I'd really love to know how to do this!
Any input would be GREATLY appreciated!
post #622 of 2597
I'm trying to get audio to play from my TV but I'm having trouble. I can get video (both from my cable box and my ipod) but no audio. I feel like my problem is a simple one that I'm overlooking so any help would be appreciated.
post #623 of 2597
Bah, rewriting this post because of weird posting issues...
Anyways, my questions so far.
1. Radio wont tune when I hit the up and down on the remote. I have to walk up to the receiver and hit the tune buttons. Is that normal? Is my remote broke?
2. Missing TiVo sounds, would this have to do with no rear channels?
3. How do I turn on game mode for specific inputs?
4. Slow switching between inputs - black screen for 3-5 sec, then green screen for 1-2 sec, then I get the video.
post #624 of 2597
Originally Posted by caridan View Post
Hello forum members. This is my first post and I'm hoping that someone here can help me.
I have a new Pioneer VSX 1021-k receiver and have a problem...while in the Network Setup menu, I inadvertently clicked "enable proxy" to "on", and hit save...now the receiver network functions seem stuck as I get a screen that has a blue circle with an exclamation point which say's "A/V Receiver...Network Setup...Applying Settings", but it just stays this way and I can't get past this.
I'm certain that I should have clicked Enable Proxy to "off", but was having network connection issues (new router and was trying to get the receiver to sync up with the right IP address and hit this by accident,) and now I'm stumped.
I should note that all of the other features of the receiver are working fine and I can use everything else as expected with the receiver, but this is very frustrating as I can't even seem to back out of this area or do anything "network related". Is there some master "reset" for the Network Setup, or other solution that anyone here might be able to assist with? Thank you in advance for your response.
Dan
Dan,
This is also my first post to this forum. Were you able to solve this problem? I am stuck.
I have replaced the patch cable to rule that out.
Reset the Router
Reset the Receiver
Please help - lost all network funtionality.
post #625 of 2597
Hi, this is my first post. I am a complete newbie to AV technology. Anyhow, I've connected all my speakers to the system; I have a cable box with DVR connected to the VSX 1021 Via HDMI and HDMI to the TV. I can see the picture on my TV but I can't get any sound. I don't know if it's a setting on my cable box. I am going to attempt to use the Navi tonight to see if I did anything wrong. This is what I have wired:
Two Front's - Followed the bi-amping instructions (Yes, speakers have Hi/Low connection in series)
Two Rears
Center
Sub
I was meticulous in my wiring, all wires labeled and double checked for signage...
Any help is greatly appreciated!
post #626 of 2597
Here's a weird one. I've had a Samsung plasma TV for months now, performing perfectly. I just connected a new Pioneer VSX-1021 and now I have problems receiving AM radio stations on the tuner, PLUS, in the basement below, an AM radio gets all kinds of buzzing interference whenever the TV is on upstairs! FM reception seems fine. Anybody know what might be going on?
post #627 of 2597
Originally Posted by akbungle View Post
I should be receiving my 1021-K by this weekend and will try out the .flac playback and report back.
Wow just noticed I've been on AVS for 10 years now!!
Did you manage to play flac?
post #628 of 2597
I'm looking at either purchasing the VSX-1021 or the Yamaha RX-V671. I will be running Energy RC-10's in the front and read and the Energy RCLCR for the center. I have an old Infinity sub that I will be using in the meantime for this setup.
Preferences between these two - anyone that has experience with both? Of course I understand there may be some biased people in this thread.
post #629 of 2597
I had a strange problem today. All my devices connected to my 1021 are with a HDMI cable. Today no signal was outputted to my Panasonic 42" plasma tv. I tried the Tv tuner, BR player and my Dune mediaplayer. The light indicator (the red bloom on the right side) wasn't burning. No way to get a video output. I had to disconnect the powercord. Then there was output on the HDMI out. What could be the possible reason? Does anyone has the same problem? By the way: everything is normal again after disconnecting the power cord! Tia!!
post #630 of 2597
Hey everyone. I picked up the 1021 tonight and am having issues with the hdmi pass through. I have a LG TV and was testing the yamaha rx-471 AVR prior to this pioneer. The HDMI pass through worked fine on that so my wife was able to just use the TV speakers when the yamaha was turned off.
I can't seem to figure it out on the pioneer, however. What do I need to do to get the hdmi pass through to work? I found the setting to toggle hdmi through... but even with it on as soon as i turn the receiver off the hdmi still won't allow audio/video through.
Does the receiver seriously have to be on at all times and will my wife have to learn to toggle this on and off?
