Originally Posted by mikek
I am not able to play Netflix at all for the last 8 weeks. It connects to Netflix and when it attempts to play a title there is a message from Netflix that says:
We are having difficulty playing this title right now. Please try another title or try again later.
This happens on every title all the time. All other apps work correctly. I've tried everything. It is not my network and the same thing happens on other networks.
Does Netflix work fine with the latest firmware for other people?
thanks.
thanks.
I only just installed 1025.1. Had to get it on USB drive.
After installing I immediately played what I KNOW to be HD - America-Story of US. At first it stalled, rebuffered etc. Then for the next 15 min. played flawlessly, rebuffered again then continued without issue. Other titles started with the same issue & then played properly. I rarely have a rebuffering issue with titles that are NOT HD.
If you have not done it, I strongly suggest you do the RESET (holding the STOP button for 8 sec,); it gets rid of OLD problem programs and might even install the newest version of Netflix, if the older one is "stuck" in your unit. If you are wireless u need to do the access code again.
One other thing I noted, that is simply bizzare. Going from playing disc to Netflix seems to upset my player. I have found that I must remove the disc & UNPLUG the unit. Replugging it, I go directly to Netflix and for the most part it works. THEN, to go back to watching a BD I must unplug again, or some of my titles will not play without stuttering.
It appears, on my unit at least, that something of the previous operating software is NOT cleared out & interferes with the operation. Simply turning it off does not seem to work. WHAT A PAIN. If that really is the case Samgsung should write code that will clear the old program & start with a clean slate--if that is the case. I only know that this tiresome procedure works for me.
Good luck, Classico
Samsung is supposed to be sending me the firmware update on disc, within 5 to 10 working days. Would have been nice if they would have offered to do that on the first phone call a couple weeks ago and not the on 4th phone call, but that's another matter.
