After many late nights (like this one!) of thread reading, designing, revising, and reading some more, I finally feel like I'm on solid-enough ground to start asking some questions.
Quick background: New dedicated HT build in basement, part of a larger basement-finishing activity. Nothing built yet, nearing the end of the planning stage.
For reference, here is a simplified layout of my HT room including my proposed speaker locations based on the Dolby 7.1 recommendations:
Due to the limited depth of the room, I'm planning on in-wall LCR's behind an AT 2.35:1 screen. Surrounds and rears do not need to be in-wall, but they could be if it makes sense to do so.
These speakers will be used 90% for movies and 10% for television and possibly music. One of the reasons I went with a dedicated space is because I want that tight, rich, "knock-your-socks-off" audio to compliment the HD video. To that end, I'm willing to put some money into the audio setup, but my pockets aren't bottomless. For instance, the Klipsch THX setup looks fantastic, but at around $8K just for the speakers, there's no way.
My realistic budget for speakers and receiver is $5-6K.
Questions:
I feel like I've got a lot of peripheral knowledge of all this stuff but very little practical knowledge, hence my outreach to you, the experienced ones. Thanks in advance for any help/comments/wisdom you can provide!
Questions:
- Any rules of thumb for how much to spend on the amps/receiver vs. the speakers? Like 50/50, 60/40, etc?
- Just Googling around I put together a $3K Klipsch system using 3X R-5502's 4X RS-52 II's and a ~$500 sub. As one with little home-theater experience, am I safe to assume I'd be impressed even with a "lower-end" Klipsch system?
- Given the budget I'm working with, I have to believe there are lesser-known brands that give you more bang for your buck than Klipsch (or other higher-end brand-name speakers). Any suggestions?
- Based on my room size, would a stand-along receiver such as an Onkyo TX-NR3008 be able to deliver enough power and clarity to "properly" drive my speakers? Or should I consider one or more separate amps?
