Originally Posted by
Chu Gai
Delays appear to be due to be some friction and miscommunication between the brothers. From the product description, they're MDF over plywood which indicates stock that was made prior to their move to the CA cabinet maker so it's been sitting around for a while.
I'm thinking that description is still for the old 18.2 model though...check this out:
SS-18.2P - Passive Cabinet w/drivers
View Full-Size Image
$950.00
Now In Stock!
This is the passive version (no amplifier included) of the SS-18.2. If you have your own amplifier, this is an excellent choice.
Add a Dayton Amp for $400 (no additional shipping) Note: Other amps are being tested and considered...stay tuned!
The new SS-18.2 has dual 18 inch drivers on the 2 inch thick front baffle. Both drivers are flush mounted, and look so good you may not want the optional grill. This front baffle is optimized to making sure your SS-18.2 does not vibrate. All you will hear is deep, tight bass.
The CraigSUB SS-18.2 subwoofer cabinet has been re-designed to add a veneer of MDF and an upgraded, hard flat black clear coat that greatly improves the fit, finish, and durability that will proudly fit in any decor. It is the same monster performer as the original version, with a relatively small footprint (for a subwoofer with TWO 18" drivers) at a price ($950 plus $195 shipping) that is as stunning as its performance. The level of value and performance rises exponentially with a PAIR of these bad boys at only $1900 (plus $290 shipping).
The SS-18.2P's response curve of +/- 3 dB from 35 Hz to 200 Hz has a natural, 12dB per octave roll-off below 35 Hz designed to match the room gain of a room requiring a subwoofer in this size and price category. All Chase HT subwoofers are designed so that, if placed within a 1/8 wavelength distance from the corner boundary, a theoretical boundary gain of 18 dB is possible. Of course, most of us don't have three foot thick concrete walls and floors so typical boundary gain will be 9 dB –15 dB. The room gain and boundary gain will offset the natural, 12 dB per octave roll-off of a sealed design, as it occurs, resulting in a nearly flat frequency response to 15 Hz or below depending on the room and placement.
Not only will you feel the deep extension of the SS-18.2P, but it hits HARD in the 40Hz – 80Hz range to maximize the chest thumping slam you want for movies, yet is tight and responsive with music. The sealed design makes it all work exceptionally well in a medium, large or extra large room.
Our hardwood plywood is noted for strength and wear-resistance. The enclosure is lightweight, moisture resistant, and has high surface quality and integrity. With the re-design of the enclosure we have added a veneer of MDF, additional finishing steps, and a harder clear coat finish that must pass additional Quality Control inspections. The result is exceptional fit and finish that matches the outstanding performance of the unit. The
dual 18” drivers are mounted on opposing sides of the enclosure virtually eliminating vibration. This lack of vibration, coupled with the opposing drivers being close to the bottom of the enclosure, makes the SS-18.2 incredibly stable.
