Originally Posted by SeaNile
Loving my subs so far. Still not used to adjusting the level of the subs for different recordings, etc. I guess for the most true representation of the recording everything should be level matched? If that is how you do it I am in the like the sub hot category.
Andrew was kind enough to come over again and aside from talking me into another amp and 4 more subs he adjusted everything and had Audyssey do it's thing. Sounds really good and is a huge improvement from what I had before. No fault of my components, speakers or subs but I really want to feel like I am at a concert when I watch concert DVD's. Looks like 4 more subs will be ordered soon. Due to space I will be going with 4 of the SS-18.1 passive subs. Looks like 4 more subs, another Crest CC4000 and probably move up to a Denon 4311 so I can adjust the audio settings on the fly.
This is still Latin to me but here is a snapshot of my subs thanks to Andrew. Looks like flat to about 14hz? After the additional subs I will toy with the idea of adding an EQ. That will also give me some time to figure out what an EQ will do for me!
BTW, when I look at that graph I would not say flat to 14hz, I would say flat to 6hz! The 15-40hz is just a huge peak to me and would lower that as one broad peak. Adding the additional subs will give you the headroom to stay flat up at louder levels. I would set the center frequency to 29hz with a cut of 6-10 dBs and play around with the Q. The lower the Q the greater the range. So a Q of .1 would cover a very large range. Someone who knows this better can tell you exactly what to use. I just tweak and measure, tweak again and measure. I keep doing that until I get it the flattest because it takes seconds.
I look forward to hearing your thoughts on them once you've broken them in a bit and had a chance to re-calibrate and enjoy your set-up. (I've had a chance to hear SHO-10s across the front w/ SS-18.1s in both my HT room and in my buddy's set-up. Very impressive, IMO.)
