(end of August - early Sept)
After much wiggling, the far wall cabinets are in. These things have been taking up space in my garage for over a year now so it is great to get them installed. I actually had to install them twice because of the change in stone vaneer (more on that later) meant I needed less of a gap to accommodate the stone.
But when it came time to put our counter top in, things didn't go as well. I measured and re-measured the heck out of that thing before we ordered the custom top. However the girl at HD who gave me all the required tolerances for the end caps actually forgot to subtract them herself. Oops. So a week later when the top arrived it was a few inches too long and didn't fit. Arg!
So back to HD and the girl realized what had happened. Turns out she is a floor manager or something, but she was great. She gave me free saw blades and offered rentals if I wanted to trim it down myself, and if I mess it up she will replace the whole thing anyway. This was appealing because I could then cut it at a slight angle to make the top fit between the walls super perfectly. She spent lots of time with me getting all the stuff I needed in the store and consulting all the old timers there to make sure I did the best way.
So in the end I cut off the excess, and I cut it at a very slight angle, and holy cow that counter top couldn't fit into that twelve foot space any tighter or more perfect. Woo hoo !
I chuckle every time.
