AVS › AVS Forum › Audio › DIY Speakers and Subs › New Mach 5 Audio IXL info
New Mach 5 Audio IXL info - Page 5
post #121 of 740
that seems almost impossible to have that high sensitivity
It looks OK for a 2.83V sensitivity (2.5W/3.2R), or 88.8dB for 1W.
post #122 of 740
I am in for 16
post #123 of 740
Originally Posted by auburnu008 View Post
I am in for 16
post #124 of 740
Originally Posted by kryptonitewhite View Post
damn it man I said F it and started entering it to WinISD, had to google HTS's entering driver data proceedure, almost done... then I see what a swell guy you were providing a download FRACK!
Give your video camera a break and start paying attention.
I noticed today on the website the price has been set at $420. I'm tempted to upgrade my twin Atlas 15's.
post #125 of 740
I am in for 16
Do you live at a hydroelectric dam or something?
post #126 of 740
Actually, efficiency increases 3 dB with every doubling in number of drivers, assuming box volume increases proportionately.
post #127 of 740
lol I have been takig it easy on the camera and the system for months now, so those few occasions I pick it back up and turn it back up I do get a little tunnel visoin 1Hz for 1minute! jk jk!
post #128 of 740
That enclosure is going to have one hell of a low port resonance with a 48" long port.
I didnt invest any time in the port, in fact I did all my plots without touching port till i decided I should get a vent velocity and changed 4" to 8" and went ...oh ****! Notch filter if there is a bad resonance? Do elbows and bends alter that? Fine! Slot port!
post #129 of 740
No to the notch filter. The resonance will still be there. Slot port, maybe. I don't really know much about those. This is where PR's shine. No crummy port resonance to deal with, ever.
post #130 of 740
Oh yeah, huh... it's not the driver creating the port resonance with the driver making it at that frrequency... helmhertz? Got it
PRs have resonance don't they? Or is that just at the tuning?
post #131 of 740
A passive radiator is pretty much a sub driver without the voicecoil. No power. They do keep a full suspension system (surround and spider) so the PR will have a Fs value. As part of a subwoofer 'system' it will have a definite resonant frequency or Fb just like a vented system.
post #132 of 740
Thanks for that correction/clarification.
post #133 of 740
The helmholtz resonance of either ports or PRs is not a problem.
The problem is the quarter wave resonance of ports and transmission lines.
Now with TLs you actually use the first QW resonance to augment the slope in driver response, and stuff the whole line with polyfill adequately to cut higher harmonics until they're down to +/- 1db at which point we can effectively call them inaudible. The tradeoff is a loss in line efficiency but the sloping response tends to work decently enough in rooms. For main speakers that means any line harmonic are NOT audible!
Not many people stuff their ports like that, especially not a for a sub optimized to only operate with a low pass filter at 80hz or 100hz for max output. The port is only there to be a pressure loaded mass of air, and any QW behaviour is just a side effect. In that sense, using a mass of something else that won't have such a side effect does make sense. I'm sure there's other small resonances higher up in frequency (IE 400hz?) but i'm not sure they'll be excited because Passive Radiators barely move so high up in frequency.
Now one might say a 140hz vent QW resonance (of a 48" long tube) is a problem. But an 80hz 4th order low pass is pretty significant imo. Here's an example of a speaker with a 110hz vent resonance:
http://forums.audioholics.com/forums...4&postcount=58
And that guy claims he doesn't hear any vent resonance.
post #134 of 740
I'm betting Mark is only saying 1200 watts because he doesn't want the car audio guys to be running 4000 watts through these things. I have 4 of the IXL18's and mine have dual tinsel leads on each of the 4 VC connections. He was saying the Car audio guys were melting them running WAY to much power. They are new and a bit of caution I'm sure is all he's asking. I ran 2 of my IXL's with a bridged ep2500 in a big ass ported box for a year and cranked the crap out of them on a daily basis with no ill results. Thats double the power they were rated for.
post #135 of 740
FWIW, I had a pair of MJ-18's (4ohm SVC, rated for 600e RMS) in 3.25cf each off an Earthquake PHD-3 (2kw RMS), great wiring but only the stock 650cca lead acid battery, for over 5 months no problem.
My buddy had a pair of his MJ-18's in 1.8cf each off an Orion 2500d (2500w RMS), even better wiring but same size stock battery, for over a year, and no issues.
I wouldn't worry about putting more than 1200w into the Pi18... but finding that kinda power in car audio @ 4ohms isn't the easiest/cheapest thing to do.
It's a good thing they're not 4ohm DVC... I'd definitely run an ep2500 per coil
post #136 of 740
I asked about the DVC option and he said it would cost more but I never found out how much more. And being tight on budget I didn't know if I could float the added price. But this is also on the 21". I am sure it can be done to the 18 as well.
post #137 of 740
I must be slow today, but what is the point of DVC for a home sub?
I'm also still surprised that so few people understand the difference between a power rating, amp power and the actual power applied to a driver under real world signal conditions.
post #138 of 740
I agree, really don't know why you need a DVC. The new blueprints are going to be a SVC 4 ohm.
post #139 of 740
I would have used a DVC to aid me in wiring configurations. SO I could use a pair for now and use four later with the LG Fp14000 clone. I was thinking of having dual 8 ohms for mine.
post #140 of 740
I'd very much prefer dual 4ohm or something like that so I can use these dual-opposed with a 4ohm nominal load. That would be nice.
post #141 of 740
ya well my deck was set to 22 out of 35 and the gain was like 4/5ths the way up!
post #142 of 740
I am in for 16
When you get them up and running, PM me. I'd love to hear 'em and you're 10 minutes away
post #143 of 740
New Mach 5 Audio Pi-18, posted today.
No logo, good.
Shorting ring in the motor, good.
No spec even given for inductance, provisionally bad (it's reasonable to assume that when something important isn't provided, it's not provided for a reason).
post #144 of 740
DS-21 - shorting rings are used in the motor. Wish they listed Le though. Glad I can get them without the logo. Now if I can just get them dual 4ohm or single 8ohm.
"Low Distortion Motor
From our machine shop comes a CNC-turned magnet structure using quality North American steel parts, high energy ferrite magnets and strong adhesives. Aluminum demodulating rings are applied to minimize distortion and a non-ferrous shield is placed within the motor to cut down on stray flux. We then run this motor through our magnetizer four times to ensure proper saturation of the ferrite slugs. Like the PS voice coil, these modifications are something you may never see, but the sonic improvements will be nothing short of spectacular."
In listed features
Features
76mm IST PS Series low distortion voice coil
Cast aluminum basket
Low distortion motor with demodulating rings
Internal stray flux shielding
Heavy Craft pulp/Carbon fiber cone
Extra wide heavy foam surround for high excursion
Conex spiders with double woven tinsel leads
Large spring loaded connectors
1200 watts RMS power handling
Excellent for home audio and home theater
34mm Xmax excursion for maximum output
post #145 of 740
What about the tall rubber surround? Is that option available?
post #146 of 740
I believe that was an option for some of those that ordered early and had custom work done. Guess it was an option to get the tall surround. I myself would like to get these with the tall surround. Though having those may change the T/S numbers to something the Mach5 guys didn't want.
post #147 of 740
You're quite right. Dunno how I missed that. Original post edited.
post #148 of 740
Wiring options. You must not have multiple subs or an IB. It can make you life much easier.
Using test tones or in peaks in movies or music, you can EASILY go over the power rating for the sub. Does it happen all the time? probably not but if you run you system hot, then yuppers.
post #149 of 740
Originally Posted by DS-21 View Post
No shorting ring in the motor, good.
Um.. what?
What advantage would there be to not using any shorting rings?
post #150 of 740
Um.. what?
Haha. Hey, DS-21. You might need to re-edit the post again. You saying that not having a shorting ring may read that as out of character. You wouldn't ever say that.
