Originally Posted by
N8DOGG
I'd not go over 800-1000 watts. It doesn't need as much power as the UXL to get pumping. I was running 900-1000 all week and it was never in distress. The coil can't handle the power like the UXL's can but it can still take plenty. 3.5 cf is the size I had the prototype in and it was great.
Thanks for the info.
Right now I'm using a pair of SubM HP's and don't really need anymore output, just looking to spread the bass out around the room better. Do you think a pair of these would keep up well?
The room is small, roughly 1800 cubic ft I think, somewhere in that neighborhood and I don't listen at reference, usually in the -10 range.
