AVS › AVS Forum › Audio › DIY Speakers and Subs › New Mach 5 Audio UXL info
New Mach 5 Audio UXL info - Page 15
post #421 of 752
Well, it took a long time but I am still building the theater so am pumped that he beat me!
Box building is gonna take me forever too so no complaints on the wait.
post #422 of 752
Will the shipping be the same on the 18" UXL?
post #423 of 752
probably not, it's a fair bit bigger and that means, the box will be bigger. Can only see the shipping being more.
post #424 of 752
Either way I am thinking of buying a pair of the UXL's so I can build Ricci's HT sub.
post #425 of 752
Mark is dropping off my FTW 21's tomorrow He said all he's waiting on is the boxes now and should be ready to start shipping very soon!
Don't worry, I'll take lots of pics
post #426 of 752
Alrighty then!
post #427 of 752
YAY!!!!!!
Matt
post #428 of 752
Originally Posted by Steve_Vai_rules View Post
YAY!!!!!!
Matt
You have any more plans for the horn?
I'm busting my butt trying to get the theater ready way can build boxes.
post #429 of 752
Well until I get the drivers no not really. Although I may delay things as I am selling my house and looking for something else. So the dimensions may change. But we will see when I get my new place.
Matt
post #430 of 752
So I got the drivers today, holy hell, these are beefy!!!! a good 15 lbs heavier than my mal-x 21's and very well built!! Mark thought the baskets were the same as the mal-x 21's were but they are not, they are MUCH beefier. These baskets look like they could fall off a house and survive!! These are the beefiest baskets I've personally ever seen on a sub. The surround is thick and loks to be well over built. I love my mal-x 21's but these things surpass that build quality by a fair margin! I've got them running on a 20hz tone for a while to loosen up the surrounds as they are pretty stiff.
post #431 of 752
Awesome N8DOGG! They look insane. Can you take some snaps up against a smaller driver?
Can you confirmed the cut out dimensions? Looking forward to hearing more!
post #432 of 752
I'd take away .5 cm to the cutout hole and everything else is golden. The flush mount hole is good.
Here are a few pics next to a Dayton 15" DVC.
post #433 of 752
Yeah I can tell a difference in the basket for sure. How do the surrounds compare to the Mals? Look like the surrounds may be a tad thinner as in horizontal width?
post #434 of 752
Wow, great comparison photos!
So, can you give us the cut out and mounting hole dimensions?
I didn't know if the 1cm was from the malx basket or from the measurements on the website.
post #435 of 752
surrounds look like they may be exactly the same lol. I measured them and they are both 3". The Mal-x has the gasket on top where the screw holes go and the FTW doesn't, thats why it look a bit different. It's nice to have the mal-x to compare it to lol.
The spider is also somewhat different.
post #436 of 752
take away .5 cm to the 51.3 cutout. So 50.8cm's. I had my boxes CNC cut and they are exactly 51.25 cm's and there is a bit of light showing through. and there is wiggle room for the sub of 3/4 cm's per side. So adding 1 cm should be good but not to tight.
post #437 of 752
I had them in the holes again, you'd be pretty safe with 1cm but if your getting your boxes built, maybe it's best to go extra safe and only take .5cm's away. So 50.8 cm mounting hole.
post #438 of 752
Yeah the gasket on top is what made me think the surround looked smaller. Had to go look at one after you said that lol. How long are you going to let them play free air before seeing how they really compare to the mals. My bet is there wont be much difference if any down low but maybe a little up higher in the music range.
post #439 of 752
On sims, they look to be extremely close, I'll be painting my boxes tomorrow and have them up and running by Friday night hopefully. I'll be letting them run free air until I got to bed and after I get home tomorrow. I'm not running them anywhere near full excursion, I'd say about half, maybe a bit less.
post #440 of 752
What midrange is that from Dayton.......LOL
Soon I will have some bass. YES!!!! Bombs will sound real again on BF3
post #441 of 752
god i want mine sooooo bad!!!!!!!!!!
Matt
post #442 of 752
N8DOGG
Well, its either really good or you're having some problems and trying to figure out whats going on with them. Lets hope you are just enjoying some damn good subs!
post #443 of 752
I had painted my boxes yesterday at work in truck bed liner and took them home today and installed the subs about 2 hour ago.
I've been cranking tunes and tones since then lol. It's a good thing I have some Clones because these suckers eat up my ep4000's with ease!!! Compared to my mal-x 21's, you can tell the FTW's have the stronger motor, they start and stop and sound a ton like my old LMS ultras I had a while back. clean and razor sharp. O man my system is so over the top for my room it's bordering on insanity!!! wooo hooo!. I got the place to myself this weekend and I plan on unleashing these the whole time!. Got a bunch of friends coming over tomorrow and 3 neighbors coming over in about a hour to check them out.
I really do think this is the best built driver I've ever seen personally and I've seen a ton of drivers! This driver could be as good as it can get.... at least for now lol
post #444 of 752
Are those 24" cubes?
So far I have been thinking of a cube or 20d x 30h x 24w. DO you have the 14K?
I will only have 1000watt on tap in 4ohm stereo. I will need to save for the 14K or 10Q next.
post #445 of 752
congratulations and great info n8!
"Compared to my mal-x 21's, you can tell the FTW's have the stronger motor, they start and stop and sound a ton like my old LMS ultras I had a while back. clean and razor sharp."
because it will come up...are you sure that you are hearing the drivers and not differences in the e.q./frequency response between the ftw and the mal-x's? in other words, have you eq'd them both similarly before judging?
post #446 of 752
I had them both on free air and with the same song, you could see a slight difference (I only did this for amusement, my comments were based on in box time lol) listened when the driver would stop and start. I guess I'm just assuming thats the BL since they were in open air. I know i should have taken a video but I really just didn't think of it at the time, stupid me I guess lol
I not really comparing the driver in their optimal box size, just what I'm running 24 cubed boxes. Though as far as a optimal sealed box, That was what Kevin told me to run as well as Mark, they though it was a good idea.
I though it may be at first the suspension but I've been running the FTW at 20hz for almost 2 full days and to be honest, I'd not think the mal-x 21 has a whole lot more time than that lol
post #447 of 752
Freakin' awesome!!!
Can't wait to see in room measurements. What size is your room? What other subs do you run?
Just curious...how do you know that the ep4000s are out of breath? What was the difference with the clone amp compared to the ep?
post #448 of 752
Sounds good so far. Where do you get the gasket tape?
post #449 of 752
n8, you suck!!!! kidding, im just jealous!!!!!!!!!!!!!!!!!!
looks good bro!!! lets see some graphs!!
Matt
post #450 of 752
I won't be posting room measurements, they are eq'd flat to 15hz with my DCX 2496 and audyssey pro and confirmed with REW. It wouldn't be shpowing anything that hasn't already been shown before. they are very close to the Mal-x 21's with just a bit more output below 25hz and down.
Room is 14x35x8 with the HT part kept within 20 feet of the 35 and open to the rest of the basement. Subs are":
4 x IXL 18's in a IB
2 x mal-x 18's
2 x mal-x 21's
2 x FTW 21's
The ib is running off 2 ep4000's, the mal-x 18's have a bridged ep per driver and the 21's have each a channel off the 2 clones. Ep clip light were dancing with both the 21's. the Clones are ummm awesome? lol. I can eq to 15hz with no ill effects with the clones (probably lower but meh), heck they are barely running LOL.
A bridged ep will get you some serious output with the FTW's and only really clips on the heaviest scenes.
