AVS › AVS Forum › Audio › DIY Speakers and Subs › New Mach 5 Audio UXL info
New Mach 5 Audio UXL info - Page 16
post #451 of 752
Originally Posted by gpmbc View Post
Sounds good so far. Where do you get the gasket tape?
PE and it's needed with these subs. I don't think it would be very easy to seal these baskets without it, as they are not a flat surface. I used 2 layers of the gasket tape and #14-2" wood screws for some serious bite. My boxes are mdf with 1.5" plywood mounting baffles.
post #452 of 752
[quote=N8DOGG;21906652] they are very close to the Mal-x 21's with just a bit more output below 25hz and down.
QUOTE]
Thats great to hear!
post #453 of 752
Originally Posted by N8DOGG View Post
I won't be posting room measurements, they are eq'd flat to 15hz with my DCX 2496 and audyssey pro and confirmed with REW. It wouldn't be shpowing anything that hasn't already been shown before. they are very close to the Mal-x 21's with just a bit more output below 25hz and down.
Room is 14x35x8 with the HT part kept within 20 feet of the 35 and open to the rest of the basement. Subs are":
4 x IXL 18's in a IB
2 x mal-x 18's
2 x mal-x 21's
2 x FTW 21's
The ib is running off 2 ep4000's, the mal-x 18's have a bridged ep per driver and the 21's have each a channel off the 2 clones. Ep clip light were dancing with both the 21's. the Clones are ummm awesome? lol. I can eq to 15hz with no ill effects with the clones (probably lower but meh), heck they are barely running LOL.
A bridged ep will get you some serious output with the FTW's and only really clips on the heaviest scenes.
Goodtimes. Great times!
post #454 of 752
N8DOGG what bandwidth are your FTWs covering?
post #455 of 752
10-80hz. I just had some friends over and we played WOTW at reference with the subs 8dB'sa over. Holy freaking crap, my poor house may be dead!! lol
post #456 of 752
N8DOGG, (I'd love to see/hear your setup!!!)
Would 2 of these be overkill in a 17x15 size room?
I have 4x MFW-15 (1 in each corner) now and have a lot of bass but I need more!
I'm thinking the 4x MFW-15 up front and 2x FTW21 in the back.
Is that too much?
Thanks for your advice.
post #457 of 752
Never to much.....just matter of budget and taste.
post #458 of 752
Is that too much?
Too much? No such thing.
Matt
post #459 of 752
Originally Posted by steve_vai_rules View Post
too much? No such thing.
+1
post #460 of 752
Guys,
Thanks for the confirmation that's it's NEVER too much!
Now the question is would connecting the 2x FTW21 to a single EP4000 be a waste?
That's all I could do cause the other EP4000 would power the 4x MFW-15's.
Does that make sense?
post #461 of 752
You would be fine.....we all here just like mass overkill and20db's of headroom.
post #462 of 752
Thanks chrapladm...
Before I pull the trigger for 2x...
Sorry to ask but what size of cab (sealed) would I need per sub?
post #463 of 752
Guys,
You would probably want a clone as an ep isn't going to fully work them out. As bosso is always pushing make sure you have proper amp head room so you aren't clipping.
Matt
post #464 of 752
I'm going to be using 2 ep4000s in bridged mode to power my two sealed enclosures. My room is 18x14. Hopefully, they'll be done by the end of April and I'll let you know how they do.
post #465 of 752
Matt
I agree with the headroom comment, but with so much power on board with the clone, aren't you in danger of driving the sub too hard that may result in damage to the driver?
post #466 of 752
You will damage it with clipping too.
I bet you would have a hell of a time melting a coil. But if you are worried about over excursion just make sure you plot you signal shaping properly or just know at what voltage thing go bad and never go above that (xmax leaving lots of xmech).
Matt
post #467 of 752
Just setup your system so that they won't get damaged I was messing around with my ep's today and to be honest, even though the clip light dances, they still had enough power to pay well above reference. I only got the clones because I wanted to get rid of my giant stack of amps and simplify my setup a bit.
post #468 of 752
Thanks chrapladm...
Anywhere from 6 cubic feet (mine are about 6.2 after driver and bracing) to about 10 cubic feet. IMO the sweet spot is 7 CF. 7 would be as big as I would personally go but I'm also in limited space but don't feel the gains are worth the extra size.
post #469 of 752
N8DOGG,
Thanks so much for the cab size recommendation.
that's exactly what I wanted to know.
Now would you know if it would be possible to get these subs at 2 ohms or 8 ohms?
Because I'll be driving both connected to one EP4000 ,I'd like to make sure it's 4 ohms total to get the full 2000watts.
post #470 of 752
Wow, can't wait to hear what you think!
post #471 of 752
Matt
Steve,
I checked that out and would love to buy one, but it's going to have to wait.
Budget is not allowing me to do so...maybe later on though.
Thanks for your input
post #472 of 752
N8DOGG,
I don't know, mine are single 4 ohm but thats what I wanted. You'd have to email Mark and ask him.
post #473 of 752
Which placement would be better for the horns, A or B?
post #474 of 752
Probably B due to better integration of like drivers. May raise efficiency closer to the theoretical maximum. And considering the spacing difference I doubt you would notice a very large change in response at bass frequencies.
Matt
post #475 of 752
Is the FTW shipping yet? I emailed Mark. Just waiting to hear back.
post #476 of 752
I was told mine would be the first to ship and that was two weeks ago when he said that. He said he thought the crates would be ready by mid last week but havent heard anything. I'll shoot him an email too.
post #477 of 752
Man this waiting thing is killing me. Lol
Matt
post #478 of 752
I just looked back at the last email and it was on the 2nd so almost 3 weeks ago he said they were being packed up and waiting on the crates. I just emailed him again.
Can someone link me to a winisd file that I can just open and model or do I need to manually enter the values. Think I will build the boxes this weekend. My plan is to build 2 boxes that house 3 drivers each and then two identical single boxes.
post #479 of 752
From the numbers I just plugged into winisd it looks like with 8 drivers and 2 14000 clones ran at 8ohm stereo I can build the boxes at 8 cuft to stay under xmax at 2.5hz.
I would have thought I would need 4 clones but using only two at 8ohm stereo will get me to xmax with 8cuft enclosures. Oh, that would be 9400 total watts or 1175 each from the clone specs.
Should I be modeling these drivers matched with the clones different or do you all think they will put out what they quote at 8ohms?
Its just weird thinking that running two amps at 8ohms stereo for 8 21 inch subs will be anywhere near pushing them to xmax.
Any thoughts guys?
post #480 of 752
Still no reply. Have you guys already been charged?
