AVS › AVS Forum › Audio › DIY Speakers and Subs › New Mach 5 Audio UXL info
New Mach 5 Audio UXL info - Page 19
post #541 of 752
WWwwwwooooooooooowww!
I am envy.
post #542 of 752
I would pay pretty good money to see a movie there then play about 5 songs till I puked!!!!
Absolutely stunning!!!
post #543 of 752
Looks awesome!!!!!!!!!!!!!!!!!!!!!!!
post #544 of 752
Originally Posted by audiovideoholic View Post
Yikes!
Ordered one FP10000 220v today and think I talked my wife into ordering another tomorrow. I wont have quite the power as Not is pushing to his 18s but 10 21s with around 2000 watts each in larger enclosures should give him a run for the money.
Its going to be interesting trying to get the linacoustic cut to fit perfect around each driver. May take my time if it ends up looking good after a couple but if it doesnt look good I'll just piece it together since they wont be scene 99% of the time anyway.
INSANITY!
Love it!!! How big is your room? I've got 2 on the way for my 2000 cuft room, and I thought that was a little overkill. Look forward to your impressions!
What subs did you have for this room before these beasts?
post #545 of 752
Originally Posted by dominguez1 View Post
INSANITY!
The room is 18x31 in front of the baffle wall 18x35 total. I have two mal x 21s that will go in there as well but the room is still being completed.
post #546 of 752
What size enclosures do these ftw 21 need to see in order to get the best performance out of them?
post #547 of 752
Well you could do 10-12cuft....but we have all established that 5-7cuft is the best average of performance and protection.
post #548 of 752
Just got my 7cf subs completed by eD. You can read more here.
Here's a quick recap!
This:
= this!
Absolutely lovin them! Crazy output, SQ, and extension!
post #549 of 752
Very nice!
post #550 of 752
Good looking room.
post #551 of 752
Boy, I bet you're glad you phoned eh? LOL looks great man!
post #552 of 752
Ya got that right!!! Not sure I would've went this way without your sage advice!
post #553 of 752
So I see n8's been hard at work spending your money too.
post #554 of 752
When are the UXL-18's coming back?
post #555 of 752
When I was at Marks a few weeks ago, the cones were either shipping or had been shipped, that's all he is waiting on I'm pretty sure. I'd think they would be close to getting to him if not already. He got a bit of a crappy deal. He build houses will only do huge runs of parts and if you can't afford to buy the whole run, you have to wait for other companys to fill up the order so they will do the run. So you have to play the waiting game. It sucks but, it's just the way she goes.
post #556 of 752
I hear that. Was just curious as it seems they dropped off the radar pretty hardcore.
post #557 of 752
Sorry for the repost (I posted this in the subwoofer forum as well) but thought this would be relevant to this thread..
Check out the video of the Hulk as recorded on Omnimic. This is from 2 FTW21s in a 7cf box powered by 2 ep4000s.
Watch the 5hz content!
post #558 of 752
Just a FYI http://www.istonline.ca/mach5_lle_18.html
i was checking these out the last time I was at Marks and they are gonna be unreal. Huge slugs, nice cones, all the good stuff. I think He must have needed something to do while he waited for parts for the UXL's lol. Mark said that a lot of guys wanted this type of sub, he listened and built it. The link is a teaser and more info will be coming shortly!
post #559 of 752
AAAAyyyyyyeeeee????
iST Ltd. "We tease you good"
post #560 of 752
That's pretty awesome!! Now he has a grand total of 3 18" models and not a single one is available.
post #561 of 752
post #562 of 752
ooof
post #563 of 752
The 15's are OOS also.
post #564 of 752
With enough power couldn't a smaller box (4 ft^3) yield comparable low end performance with higher SPL up top, while maintaining the same excursion protection?
I'm curious to know how much the required power plays a part in determining the 7 ft^3 as the sweet spot for this driver.
post #565 of 752
It matches up well with around 2000 watts which just happen to be what the fp10000 clone is rated at. That is why I chose just under 7cuft. If I wanted to use the fp14k clone I would have had to of put them in a 4-4.5cuft enclosure which had me worried about thermal protection of the driver. Its really just matching the enclosure to the amp not the enclosure alone.
post #566 of 752
audiovideoholic,
I take it you are running your 21's of each channel, no bridging.
Scott Simonian mentioned you could have wired two drivers per channel for an 8ohm load, bridged, sparing you the purchase of a second amp. Did you get to try it.?
post #567 of 752
2kw will be fine in 7cuft for the FTW-21. ~4cuft you could go 4,400w per driver if thats the case.
post #568 of 752
Originally Posted by bodhisafa View Post
audiovideoholic,
I have each driver on each channel. Bridging will give me the same power but less per driver if ran 8 on one amp so just running stereo. 8ohms bridged and 4ohm stereo are the same output. I need three amps to drive all 10 of the drivers though. I would def need bigger boxes if I were to ohave ran all 8 off one amp then the remaining two drivers would still need an amp. I can easily clip the amps with 4 channel stereo at 4ohms. They run out of power well before the speakers limits.
post #569 of 752
Thanks guys. I just finished reading through AVH's thread. about the clones. Lot's of good points made.
I'm modeling up some enclosure ideas - even if I wanted to go for 4 ft, the resulting box would have to be awfully squat front to back.
You say 2,000, but in reality it is a little more than that, right? The FP1KQ clone lists 2,100 watts at 4Ω and 2,500 at 2Ω. With the Re of the FTW-21 at 3.2Ω, the driver is seeing something closer to 2,260 watts. I'm not trying to split hairs, I'm just making sure I'm understanding correctly.
...Its really just matching the enclosure to the amp not the enclosure alone.
This is making sense now... you were planning to make use of two FP1KQ's for your 8 FTW's. For my purposes, with only two FTW's planned, I ought to be thinking about the amplifier before setting my sights on a particular enclosure volume. The FP600Q clone looks pretty suitable with 3kW x 2 at 4Ω bridged. A 5.5ft box would put xmax at just over 5hz and 40mm at 3.5hz.
post #570 of 752
Impedance is not flat, it has a curve. There is only a very small area that is as low as the rated Re.
