AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Panny G20 THX vs Custom picture mode?
post #1 of 6
I'm stuck between using thx or custom. I've used D-nice's settings and service menu off-sets. Both look great. THX has more accurate picture and more depth, while custom has more pop and excitement,but it's almost impossible to get rid of the green tinge in custom unless u turn color way down. Just wanted to get some opinions
post #2 of 6
Can't you get the pop of custom by going into the THX advanced settings and setting the gamma higher, to like 2.4 or 2.6. Then, ensure your brightness setting is still correct.
post #3 of 6
NA G20s don't have an Advance mode where one can play with gamma settings.
post #4 of 6
D-Nice what are your settings for the G20/25 , where can I find them? thanx.
post #5 of 6
post #6 of 6
Originally Posted by LarryInRI View Post
Thanx Larry
