Originally Posted by Steve Cebu
Hi Ken, I've just been catching up and it looks like you are up to your 3rd TM900 now?
I returned mine, and will wait to see what happens with Canon over the next couple of months.
off topic but CCI just finished the review of the CX700 and it doesn't look very good for Sony.
Hey Steve, glad to see you're feeling better. Yes, the 3rd unit is the best behaving piece thus far. This unit performs better in low light in terms of not having the focusing anomaly the 2nd unit had. I'm also getting an even focusing across the field of view. The difference is very significant.
Although initially I thought this unit was 'beepless', I was wrong. Fortunately the beeps are lower in volume and, for whatever reason, they show up less often. Truly bizarre.
The most interesting this that happened was in my final test before packing up the 2nd unit. I took an outdoor A/B with the 2nd & 3rd unit, pointing both units toward a few buildings in the distance. To my surprise, the 2nd unit showed a bit of the bondi-blue issue...a definite 'blue-green' cast to the sky. In reality the sky was a pure blue, no cast at all. The 3rd unit rendered that same area perfectly, pure blue with no cast at all. So I was pretty happy seeing that.
However, IMO it shows the bondi-blue issue is not truly 'solved' and may pop up with some units.
Regarding the low light tests conducted by CCI and their knocking of the Sony's performance in that area, IMO they are clearly wrong. I've played with both the 560 & CX and they are both unquestionably (IMO) better in very low light than the 900. There is no comparison in terms of the noise generated by the Sonys vs the Panasonics. CCI heavily weights 'sensitivity' in their opinions of low light and I disagree. A bright and noisy picture is not a quality picture IMO. I'd rather have a dimmer, noise-free picture any time. Unfortunately I just couldn't get excited about the Sony's outdoor performance...certainly relative to the 900.
