Originally Posted by
markr041
The latest version of PMB accepts TM900 clips, and you can even edit them (trim). But it did not allow me to merge them to make a video.
HD Writer AE 3.0 allows you to trim and merge clips to make videos that are totally glitch-free and with no re-encoding. The software, unlike PMB, also has a set of transitions between clips that can be used.
This video was made using HD Writer; my first use of the software. The downloadable video is thus original quality.
http://vimeo.com/33826041
Birds, turtles, a fish frenzy, graduates, a model, soccer, lily pads, flowers.
Intelligent telephoto mode used (700mm).
108060p, manual mode except WB, ND filter.
Thanks Mark for the PMB info. That's a bummer that it did not let you make a movie with the TM900's files..oh well. HD Writer's capabilities have improved, so I'll check that out when the time comes.
alokeprasad
I don't think that AVCHD disks support 1080p. As far as I know, they do 1080i.
Is there ANY solution (software, hardware) that creates 1080p optical disks that would play on a blue ray player?
Until I get that (or the WD media player), what's the best way to play 1080p recordings?
Through the TM900?
What method would I use to copy my archived 1080p clips on to my TM900?
AVCHD 2.0 supports 1080/60p disc's. But you need a device that supports AVCHD 2.0 disc's. Sony Blu-Ray Players are the only devices that I know of that currently support AVCHD 2.0 disc's. I believe their line of *80 series BD players will do so with a firmware update installed on the Blu-Ray player.
You can get a Sony blu-ray player to play back the native TM900 files via HD, or flash drive thru the USB port on the BD player. I don't know of any other manufacturers that support the 1080/60p files but I think Panasonic or others might have BD players that do support 1080/60p files via USB. I just don't know of any off hand.
The WD Live products supposedly support 1080/60p playback so you could give them a try. Just make sure that wherever you purchase from they have a good return policy if it doesn't work, or your not happy with the product.
I have not tried to copy files back to the TM900 for playback, but am pretty sure it can be done. Search here for the Panasonic TM700 thread and you should be able find out how to do that in the thread.
alokeprasad
When I connect the camera to the PC, the software take a long time to "Register" the data on the camera before it can copy the clips to the PC.
Is that normal? What is it doing when "registering" whatever it is registering?
Aloke
Yes, that is normal. It is registering/reading all the files before copying. If you have a large amount of data/files it could take some time.
