Originally Posted by
alokeprasad
Looks like an interesting choice as the most compact case for this camera. Please let us know how this works with the TM900+VW-VBN260 battery.
I might even take the neck strap from my now retired Sony DV camcorder and attach it to my TM900 (to the handstrap, I suppose ...). I hate using any equipment without a reassuring neck strap.
It will be ironic to use a Sony case and neckstrap, with Handycam logo all over it, for a Panasonic.
Aloke
PS: I am thinking of this case, which has some mpre space for remote, CF cards, battery+charger etc.
http://www.amazon.com/gp/product/B00...=ATVPDKIKX0DER
alokeprasad
Are you creating data backups on DVD? or burning AVCHD disks (for playback on BD players)?
One would lose quality if starting with 1080/60p and creating AVCHD on DVD.
I am also ending up with longer edited video files of events, like high school football games, music concerts. HDWriter splits these into 4GB chunks, so I suppose I could do a data backup of these on to DVD's.
I'm thinking of getting a BD writer just for the larger capacity of the BD disks. Will HDWriter or Nero then create playable BD disks with 1080/60p files on them?
Ok first off I no longer have my TM900 I now have a Canon HF G10 and it's bigger than the TM900 it will fit in that Sony case no problem. The local store had one (I didn't buy it at the time
) and I put a full sized camcorder in it with no issue.
If you want a small case that literally will hold everything, buy this one.
http://www.amazon.com/Lowepro-Nova-1...4752958&sr=8-1
I own this case and it will attach to your belt, it has a shoulder strap and carry handle as well plus a waterproof cover that tucks away. I have 3 spare batteries in it, my mini pistolgrip tripod, a LCD hood and it holds my HF G10 with the lens hood on! I also keep my cameras remote and a few other things in it. I have pics of it somewhere on here if you do a search for it.
I have worn this on my belt all day on trips but I lighten thee load at the hotel as much as I can. If it's going on my belt I only take the camcorder with lens hood. the 3 extra batteries, the LCD hood, the pistol grip tripod and the remote.
My HF G10 has 2 SD card lots in the camera setup for relay recording, So I don't carry a spare.
This is the biggest small case you can get, lots of pockets too.
I burn my files to DVD for archival purposes but they will play just fine in my PS3.
