AVS › AVS Forum › 3D Central › 3D Displays › LG PASSIVE LW6500 dedicated thread...
LG PASSIVE LW6500 dedicated thread... - Page 75
post #2221 of 2463
Originally Posted by schaefd View Post
Here's a problem that has made me very frustrated. I have to contact LG about it still, but maybe someone else has an issue.
My neighbor, on the same side of the house the tv is on has a wireless connection. He's obviously not to bright, because the connection is wide open. No WEP key. My signal is stronger and I have a WEP key. When I select my router, I enter my WEP key and I'm connected fine. That's until I turn my tv off. Once I turn it back on and check the Internet Connection, it picks up my neighbors router and connects automatically to it. I have to search for my router, select it and enter my WEP key again to connect. Why does the tv keep selecting the open connection and not stay connected to my router. It's a pain to keep entering the WEP key everytime I turn my tv on.
Maybe it's an issue with your router if you can't nail it down to anything on the tv. Try do a chat support talk with your routers manufacturer. Otherwise it's obviously something on the tv and I'd contact LG.
post #2222 of 2463
I'm thinking this is a bad update and think I may go back to the previous version. It's very annoying.
I'm having the same issue. How does one go back to an earlier version??
post #2223 of 2463
FYI, I sent an email to LG Support today and this is the response I got.
"I apologize for the inconvenience this has caused you.
We have forwarded this issue to the factory for investigation and if required correct through an update."
I found this on another Forum and appears to fix the lag on the tv.
Go to SETUP > SUPPORT > Initialization of Premium ONLY!!!!
Turn your tv off then back on.
You may lose some of your settings, but it appears to work. If you try before me, let me know if this works.
Link found here: http://www.avsforum.com/avs-vb/showt...3#post21890973
post #2224 of 2463
OK I did the initialization of premium. I went into menu then to support at the very bottom and the selected initialization of premium and so far problem is solved. I didn't lose anything at all as far as I can tell, I think what the ppl on the other tread was talking about was losing the settings in the service menu but I haven't had any problems and from what i read nobody else did either. So it did solve the problem it is responding just as quick as before the update.
post #2225 of 2463
I hate it for us all but I glad to see I am not the only one have BIG Problems with this New update. I can't get the Home to come up 90%of the time when I do get it I can't get any of the Function buttons to work. I want my old Firmware back.
post #2226 of 2463
i just got my tv last friday before easter haven't had alot of time to play with it, but so far uniformity of screen is pretty good, not perfect, but we are happy, with these update firmware issues, i am scared to update my 65 now....hope it gets resolved for those with issues on the home screen lag
post #2227 of 2463
Originally Posted by upinclouds View Post
i just got my tv last friday before easter haven't had alotwill not go away of time to play with it, but so far uniformity of screen is pretty good, not perfect, but we are happy, with these update firmware issues, i am scared to update my 65 now....hope it gets resolved for those with issues on the home screen lag
The problem with the home screen lag will only stop if you initialize the premium. You have to turn the TV off and then turn it back on, once u turn it back on the home screen will come up fast and work without lag so u can get to the setup menu and go to the last option which is support and open that and initialize premium. I did mine about an hr ago and it still works fine without any lag.
post #2228 of 2463
As I stated above, do the following. I tried tonight and it worked for me. Once I did it, my Premium Apps also updated via a separate software update.
Goto HOME>SETUP>?(last tab at the bottom)>Initialization of Premium
Select it and click OK. Wait for a minute and the TV will restart. Click on HOME again and you should see a message saying your Premium Apps are updating to a new version. Once done, it says Successfully updated. At this point, you're good to go. Problem solved.
Enjoy your TV again.
Dave
post #2229 of 2463
Does anyone one know if this set does native PAL?
post #2230 of 2463
It appears that it does and a damn fine job of it too!
post #2231 of 2463
SteveCaron can you give me some idea about your native PAL question? Does this mean you can put PAL region DVD's and see them on the tv,or does this mean for example you have files that are PAL and thru USB or media server can play back fine on your LG set?? I am not aware too much about the working of native PAL.. just trying to figure out what you were all asking...
post #2232 of 2463
so in general what has the new firmware and app update do the tv?? anything noticeably better?
post #2233 of 2463
How do i access the general calibration settings on my 65Lw6500? it seems like i clicked all over the place and cannot find the contrast, brightness, turn motion on/off and all those goodies? can anybody give me a quick guide? it seems like i have pressed all the buttons and nothing?
post #2234 of 2463
My question was directed towards PAL DVDs. THe Oppo out puts PAL on those discs and when you allow the OPPO to do this you will see improved picture quality. I have a copy of Cook the Thief and her Lover from the UK in the PAL format that looks absolutly fantastic on this TV.
post #2235 of 2463
Just joined the club.
Saw this TV on buydig.com for $2299.00, went over to Amazon, they price matched it.
Purchased it from amazon.com for $2299.00, no tax, free ship.
went to costco and picked up squaretrade extended 3 years for $99.00
paid with American Express Card, auto get 1 year extended warranty
post #2236 of 2463
Press HOME button then to SETUP then to PICTURE settings.
post #2237 of 2463
Hey everyone. I just wanted to post this its kinda interesting to try http://www.xrite.com/custom_page.aspx?PageID=77&Lang=en it test how well you see your colors. I scored a perfect 0 it ranges from 0 to like 1590, idk if thats awesome or not but it says that 1 out of 12 men have some kind of color deficiency and the lower the number the better so i guess im not 1 of the 12. What a relief.lol All joking aside it is pretty interesting check it out.
post #2238 of 2463
Ok my trusty forum friends. I have an RCA remote.. It's the one with the guide button instead of the go back button. I actually "borrowed" it from my mom on a recent visit to her. The remote now can partially control my 55lw6500.it controls volume and pretty much everything else. I am ready to explore guys. Explore the THX settings etc. I've had my tv since October and it's time to take the training wheels off. On my remote when I hit the GUIDE button the tv asks me for a code,and I am totally lost. LOL .please help me guys. Thanks. Eagerly awaiting help :-)))
post #2239 of 2463
SOMEBODY HELP ME. I GOT INTO THE SERVICE MENU OF MY 55lw6500 and accidentally changed one of the standard values and my damn tv shut down on me. What I need is the DEFAULT NUMBERS FOR TOOL OPTION 2.. Right now I have 5555 but I know that is wrong because it disabled just about ALL of my inputs :-((((((. Under tool option number 2
post #2240 of 2463
Ok. I was able to use a value from a site I came across to get my tv running again. Pheewww. Word to the wise. TAKE A PICTURE OF THE DEFAULT SETTINGS BEFORE MAKING ANY CHANGES..I found a THX value of 0 and changed it to 1 but I don't see a change in the pic. Maybe it's me. Am I missing a step?
post #2241 of 2463
You should see the added choice in the Picture Mode list in the Picture Setup menu and also in the Picture Mode list from the Quick Menu.
post #2242 of 2463
Setting the THX option from 0 to 1 simply enables THX on your TV. So, when you've finished making these changes in the service menu area and are back to the normal everyday use of your TV, then you should now see THX (maybe THX Cinema and/or THX Bright Room) listed among the other picture modes that you can select, such as Vivid, Cinema, Game, THX, Expert, etc.
post #2243 of 2463
When it came time to take the plunge into the Service Menu area of my 47LW5600 to activate THX, I found the following post to be a very helpful guide thru this puzzle: http://www.avsforum.com/avs-vb/showt...8#post21257438
post #2244 of 2463
The sound on my TV yesterday was just randomly cutting out I had to cut the TV off and back on to get the sound back. Has anybody had this, I'm wondering if its the update that hit the other day because of the other issues its had. I've got about 9 days left to send it back, I bought it used from amazon warehouse deals so there is no warranty and i want to send it back before times runs out if i need to. It hasn't done it yet today but it hasn't been on as long today either so...
post #2245 of 2463
Dave
It didn't work for me. It only works until I turn the TV off. Once I turn the TV back on it's back to the lag. I did the firmware rollback trick mentioned in another thread and that worked taking me back to 04.02.28. Looks like I'll wait until the next update after 04.03.01.
post #2246 of 2463
Really? I tried it and it fixed the lag. Bur now, HULU doesn't load. Could you [post a link to reversing the update?
post #2247 of 2463
Here you go.
http://www.avsforum.com/avs-vb/showt...4#post21905524
post #2248 of 2463
Hello guys!
Im enter on service menu of my 47lw6500 and turned off AUDIO EQ option for eliminate optical output sound lag. But when i power off the tv then the option back to on .
Anyone have any fix for this inssue?
Thanks and very very sorry for my english.
post #2249 of 2463
OK I need some input, I posted this on another thread but I'm gonna ask here to cause I need help asap. OK i currently have the 55lw6500 and it is scheduled for pick to return to amazon and the plan is to replace it with the 55lm6700 unless someone knows why I should keep the lw6500. I know the lm6700 is 120hz vs the lw6500 is 240hz that's not a big deal so no need to mention that, I know all the stats I've compared the two but I'm looking for someone who has seen them together or knows more technical things about them. If anybody has some input on the two like PQ or features or just if u think I should just do it straight up or not do it just let me know what y'all think. I've got till 2pm 2maro to cancel, they are set to pick it up between 2 and 7 so i need some input asap. Thanks in advance...
post #2250 of 2463
So how are you returning it to amazon for that tv? Got my 55lw6500 in oct. last year. What features of the new tv is justifying you wanting to replace?
  Back to Forum: 3D Displays
