The TV (LG65LW6500) is not without its issues, light bleeding on edges, some weird picture issues on panning shots with blue (sky) or green (grass) background, input lag.
The SD picture is average and the picture quality suffers if viewing angle is off centre.
On the other hand the HD picture is really nice when picture adjustments are set up correctly and the 3D is awesome.
For those guys that use the "Media Link" function on the TV with Plex installed on their computer, there is something that you really need to try.
Install the Plex "unsupported plugins. You get access to Icefilms & 1channel with all the TV Shows and Movies you want and it works great!!
Better than my ATV2 with XBMC installed, you don't need any other device connected to the TV and the links seem to load faster. Try it
http://www.totalhtpc.com/plex-unsupported-appstore/
“If you the Applications Menu doesn’t show up on your OSX or Windows Plex client, enable it in the default (Mediastream) skin [Preferences > Skin > Home > Show Applications]. If it still doesn’t show up after you’ve installed the Unsupported Appstore, see below.
If the Unsupported Appstore doesn’t showup after installation, try Disabling Capability Checking in the PMS preferences found in the Advance Section”
Check to see if the unsupported App store shows under “Video Channels” on the main screen.
