Originally Posted by
brdhowell
Has anyone found where to buy the LSW600B or have you bought a universal from another vendor? Seems to be hard to find a bracket for this TV on first glance. Thanks.
I found my LSW400BG mount on eBay, but sold as a new, in-the-box product by an eBay store, rather than from an individual. I think I only paid $58 for it (buy it now price), with free shipping. What was strange was that the vendor also has their own online website, where they were selling it at the same time for $79.99. Other online prices for the 400 size were even higher, all the way up to $149 (which I wouldn't have paid). The problem with getting an LSW600B this way is that I think it is much less prevalent. But it would be worth a search.
FWIW, I'm pretty happy with my mount, and like how it operates (with tilt up and down, as well as a bit of side-to-side, and also the ability to pull everything away from the wall by 8" or so). It was also very easy to mount the TV, as well as do some fine-adjust of the leveling.
The two disadvantages of LG's design are that 1) they only fit one size of VESA spacing (400x400 in my case, 600x400 in the LSW600), so they may not work with a different TV, down the road. 2) any outlets or plates you put in for in-wall wiring, need to be either above or below the mount, or to one side, as there is no "hollow area" in the middle. This is not really an issue, unless you need to go to a different mount down the road.
In the end, I probably would have been just as well-served with a more generic tilt-mount from Monoprice, but given the low price I paid for the LG mount, I'm quite happy with it.
