Originally Posted by Five28
I would guess that since your TV doesn't support ARC, you would have to go into your TV menu under the audio section and select multichannel output. I don't know if you are using a cable box but if you are you might want to simply run the optical cable from the cable box optical out to the receiver optical input, bypassing the TV entirely. That's the way I have mine setup and I haven't had any problems.
Thank you; I have since realised this by looking at my parents set up. I am yet to buy a HD box but will be getting one soon so will run the optical cable as you said when I have it. I will have a look at the TV settings for now, but I guess it isn't so bad that daytime TV isn't running surround sound.......
Thanks again for your help
