50/50Originally Posted by richardgnz
I was really happy with my 55d6000 until it developed a dead pixel. I then had the LCD replaced under warranty and it has come back with some bad clouding.
It is only visible in dark rooms with dark scenes but it is always there and really ruins scenes as the same areas of the screen are brighter...
As you can see from the photos there are two "clouds" in the middle of the right part of the panel that really detract from the viewing.
I run the set in Movie mode with a backlight of 6 and everything turned off. I can reduce the clouding a little by setting Black Tone to Darkest and Shadow Detail to -2 - but even in doing this I can still see the clouding, Further by using these settings I would be seriously compromising the picture....
I am sending it back for repair again... What do you think my chances are of actually getting a replacement that works?
I will probably not consider a new TV again until they fix the side angle shots or OLED comes out.
