Originally Posted by CessnaDriver
I'm going to try the AMP settings tonight and watch ABC before/after to see if I notice any changes.
I am having difficulty describing what happens. I understand in sports and some fast scenes there might be a studder or pixelation on a part of the screen at times. But what I am seeing on these ABC programs are almost "pauses" of the entire picture and then it catches up. Its really weird. So far we haven't noticed it on any other channel, Xbox or Blu-Ray.
Not sure if AMP is exactly the same as the 2010 models, but many people had the exact same problem you describe, including myself. Usually refered to as skipping or stuttering. It is very dependant on what you watch and keep in mind that most digital cable is heavily compressed and well... crapy. Gives AMP a real hard time. "Clear" setting always works best. I personally love the "soap" effect and you do get use to it, doesn't look as "cheap" after a while but rather looks REAL which I can't see as a bad thing in any way. But the Clear setting has barely noticeable "soap" and people who HATE the effect are really just whiners if they say they can't stand AMP on clear.
You WILL get used to it and clear is very subtle. As an added bonus, clear has no skipping, artifacting or other issues. It also eliminates the problems you see when AMP is off. I prefer MORE soap effect so i don't use Clear but it is the only setting with no issues at all.
and the sound is very good for that kind of small profile, and w/ the wireless sub there is no cable to mess with..
