AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Official Samsung UNXXD6000 Owners' Thread
Official Samsung UNXXD6000 Owners' Thread - Page 102
post #3031 of 3049
Samsung approved the exchange...now I wonder if I'll get a new D6900 or ES model.
post #3032 of 3049
For my exchange (for the D6900) I was offered a ES6600.....I refused.
I asked for a ES8000, both have ultra-clear panels and top features/options.
Samsung called back and offered a ES7100...I took the offer.
I believe I could have held out for/ negoitated the ES8000 but didn't want to wait for weeks....
post #3033 of 3049
Wow what an upgrade
post #3034 of 3049
Please help! I'd reset factory settings in the service menu on my UN46D6000 and the tuner seems not working. Please to all owners of the SAMSUNG UN46D6000! Can you save your tv settings in HOSPITALITY mode TV to USB and send it to me. Thanks in advance!
post #3035 of 3049
Hello! I have the same model of SAMSUNG. Can you help me, please? I've reset all my settings in the service menu and all my channels disappeared. May you save your settings in the service mode by HOSPITALITY MODE - TV TO USB and send me this file? Thanks in advance.
post #3036 of 3049
Digital Noise Filter set to Auto and MPEG Noise Filter set to Auto for DirecTV really improves picture quality.
Especially with Film mode set to Auto1 with a 1080i source (like DirecTV).
post #3037 of 3049
Upgraded to 1025 firmware this eveing. All is well with the TV so far. Apps run fine.
post #3038 of 3049
I did the same and screwed up my HDMI calibration, I tried this pattern http://img94.imageshack.us/img94/9644/checkerboardsamsung.jpg and it did good to my TV.
First time I tried, it did not work that was because I had this picture in fullscreen mode in my laptop's screen.
Then I tried extending my screen into my TV fully blown up. and tried the calibration again, and that was the trick. Hope this helps.
Regards.
post #3039 of 3049
Hey all,
I own a UN40D6000SFXZA (http://www.samsung.com/us/support/owners/product/UN40D6000SFXZA) and I'm having a couple of weird issues.
First, I noticed that under the general->system info menu, my TV is identified as a UN37D6000. I talked to Samsung Support and they said no such model exists and my serial number confirms I have a UN40D6000SFXZA (this is all on the back of the TV), so it must be a firmware issue, and that they wanted a tech to look at it. They, of course, want me to pay for this (the TV is not under warranty) so I declined.
Is this normal for the TV to show up as some random model #? Any way to fix it if it isn't? I tried Factory Reset from the Service Menu and the Regular Menu. Neither worked. I also tried flashing the firmware located at the link above, and the system says no compatible firmware was found on the USB stick.
Second, I'm having weird video sync (?) issues on the VGA port. Using a VGA scaler that I own which outputs at 640x480 @ 60hz results in a unstable, shaky/jittery image. The image displays just fine on my 24" Asus LCD Monitor, but the Samsung doesn't like it at all. If I hit the "Auto Adjust" setting, the picture looks perfectly fine and is stable, but, as soon as it is done, the picture goes back to being a dance party.
Any help is appreciated!
post #3040 of 3049
Anyone know if it's possible to hack the amazon video streaming app off of an E series and stick it on our amazon deprived d series?
post #3041 of 3049
Anyone notice there is a new firmware for the Samsung D 6000 series? On Samsung's webpage it has version 1030.0 which says was released in Oct. The odd thing was my TV had 1029.0 and said it was up to date. So I downloaded the firmware from online, ran the update from the USB stick. The TV now listed 1030, and then when I ran check for update, it said it found a new update (1030) and redownloaded/reinstalled it. I checked again and it said it was now up to date.
post #3042 of 3049
Its been a while since any updates in this thread. Ive been experiencing some problems with my set. I use the harmony 700 remote to control my setup and sometimes when I hit a button it will act as if I hit it twice. Such as when I hit channel 3 the television will turn to channel 33 (no cable box) or when going down a list it will go down twice even though I hit the button once. Thought it was a harmony issue, but when using the original samsung remote it still occurs. Anyone else with similar issues?
post #3043 of 3049
Originally Posted by BigDaddySlappy View Post
Hey everyone
I own a Samsung UN55D6000 and I absolutely love it. I just have one minor issue I am hopint can be corrected.
While I dont use it for movies I use auto motion plus set to smooth in games. I love the super smooth look it gives to games.
However i notice when the speed of the game picks up and the camera is movin fast the lower left corner of the screen gets a tad jumpy. The other corners of the screen are fine. Ive messed around with custom motion settings but as soon as you end up with that super smooth moving picture...it does that crap in the lower left corner again.
Has anyone else encountered this? If so is there a way to keep the super smooth video and get rid of that issue in the lower left corner of the screen?
I have the exact same set, and I know what you mean, the artifacts only occur in the lower part of the screen, usually the left corner (though maybe a pan the other way would put it in the lower right corner). But always the bottom. I think this is a bug or the hardware is too slow, but no combination of settings I tried would make it go away. (Most recently I tested this on a blu ray.) In any cause it makes the smooth setting unpleasant for me, so I use AMP clear, which I'm happy with.
post #3044 of 3049
Can anyone possibly give me the dimensions of the stand for the UN55D6000? I'm at work and need the dimensions to cut out a piece of plastic to place under the stand to raise the tv about half an inch in order to clear the center speaker which I recently purchased.. Thanks in advance..
post #3045 of 3049
My UN60D6000 = 13 1/4 x 21 1/4. Might be same or close?
post #3046 of 3049
Thanks.. From the specs on the Samsung site, I was able to determine that it's 12 inches wide but nowhere does it state the length.. Looks like the size for the 60 inch is a little different.. Thank you anyway..
post #3047 of 3049
Just had a guy from the Geek Squad do a free calibration on my Samsung UN55D6000. I'm a Silver Premiere Rewards member so I was able to pick one free service. I originally had planned to calibrate a 55" LG that I had purchased last month for the living room. But since I watch most of my programs on the Samsung, he recommended I go with that.
Words can't describe the difference the calibration has made. My previous settings were either from this site or tweaktv.com. The picture now has so much depth. It's truly amazing. I watched Forrest Gump last night and Iiterally felt like I was walking through the rain forest of Vietnam!
Here are my previous settings:
Color Temp: Warm 2
Backlight 16
Contrast 87
Brightness 44
Sharpness 20
Color 48
Tint G50 R50
Gamma 0
Here are the calibrated settings:
Color Temp Warm 2
Backlight 7
Contrast 100
Brightness 40
Sharpness 0
Color 50
Tint G50 R50
Gamma -3
So as you can see some settings were closer than others.
But here is where I feel the difference comes in:
These settings are found in the Advance Settings of the Picture mode:
White Balance: (Pre Calibrated) Red, Green Blue (Both offset and Gain) were all set to 25
White Balance (Calibrated) Red offset 16 Red Gain 41
Green Offset 21 Green Gain 29
Blue offset 21 Blue Gain 0
Then finally the setting Color Space.. First you have to assign to Custom. Then make these assignments
Red Red 65, Green 0, Blue 0
Green Red 0, Green 61, Blue 0
Blue Red 0 Green 10 Blue 75
Yellow Red 59, Green 54, Blue 0
Cyan Red 0, Green 60, Blue 38
Magenta Red 44, Green 2, Blue 41
With the calibrated settings, skin color is so lifelike, even subtle shadows are noticeable. My picture before calibration was washed out in white. No Longer is that the case. I'm really enjoying the display!
post #3048 of 3049
Contrast at 100 doesn't seem right. On my 60" D6420, the highest I can go is 89 without clipping or a color shift. I have it set to 88 for a bit of headroom. Also, gamma at -3 would be way off on my unit. Sounds like you're happy though, and that's all that matters.
post #3049 of 3049
Have a UN55D6050TFXZA that has a power issue. We have to leave it unplugged for long periods of time (probably days) before we can plug it back in & power it on. My first inclination was a capacitance issue of some sort. I've seen that Samsung had a big problem with capacitors in the past on their LCD power supplies.
Has anyone had this problems with the LED TV's? Or does anyone have a thought on this problem? Hate to junk the TV when the problem is not a seemingly final issue.
Also, this TV does seem to have a few LED's out in the lower left corner. Any experience or fixes for this? I haven't opened up this TV yet.
