AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Official Samsung UNXXD6000 Owners' Thread
Official Samsung UNXXD6000 Owners' Thread - Page 103
post #3061 of 3067
Anyone plus an Xbox One into this tv and what setting they use?
post #3062 of 3067
Anyone have a problem whereby the screen just goes black...no video? There is just a hint of the hue that used to. Be displayed before the set turned on completely. We tried a different cable input different sources ...all look the same. I believe it's something easy to diagnose but can't find anything here that indicates others had this problem.
post #3063 of 3067
Hey all,
Long time reader...first post!  Just want to say thanks for all the useful information floating around here.  I own a Samsung UN46D6000 and have a question regarding how the set saves the various setting profiles.
For instance, I have my Cable box plugged into HDMI 2 and XBOX 1 plugged into HDMI 4.  If I set the display to my custom "standard" settings while watch TV (HDMI 2) and switch to XBOX (HDMI 4), will those settings carry over or can I create a gaming profile using another "standard" profile?
Basically, do the settings save to the input or to the setting description itself (standard, dynamic, movie, etc.).
In total I'd like to have a standard set for watching TV (HDMI 2), and standard set for gaming (HDMI 4) and a movie set (also HDMI 4 since I use the XBOX for BD and Netflix streaming)
Thanks for your help!
post #3064 of 3067
Originally Posted by reillygj View Post
Hey all,
Hey Reilly. The settings don't carry over. Whenever you switch inputs, you are looking a whole new Movie/Standard/Gaming etc profile settings that you can customize.
post #3065 of 3067
Awesome...just the answer I was looking for!  Also, I'm currently on firmware version 1025 I believe.  Is there any reason to upgrade to the latest?  I read the update notes and didn't find anything that would affect my viewing.  Mostly app updates which I don't use.
post #3066 of 3067
Ya, I don't use any of the apps or smart features myself and I have not upgraded the firmware since buying it almost 2 years ago.
In this case: If its not broke, don't fix it.
post #3067 of 3067
Mine is up to date and nothing has broken as far as I can tell. I do use the smart features which are quite usable. Only thing missing is the Amazon Instant Video app :-(
