Originally Posted by
spjoneser
Guess I'm gonna have to start over, it was not that easy for me. My Tv and computer are both hard wired to router. I was previously using Mezzmo which did work out of the box. When I first tried ps3mediaserver I checked the log and there was a port connection error. After running as administrator I had no more port error but still not visible on tv source list. Should I see tv listed on the renderer screen?
After a connection is made, it should show up.
About 10-15 seconds after PS3mediaserver is running, pressing the source input button on the TV, you should see the PS3Mediaserver listed.
I set mine to always run as administrator. It does run a webserver type application, so it might be getting blocked by the firewall, make sure you allow any connections from the mediaserver.
Devin1886
Thanks for your help Nitra. I tried these settings and it seemed to help diminish the flash lighting. I have another question about the qwerty remote. I have it synced with the TV but when I try to use the keypad in the search bar of the browser it doesn't work. Any idea why I can't type with the keyboard?
The keyboard side of the remote is a little iffy at times, it needs to be pretty level to switch to the keyboard mode, but it should be working. Keep in mind, it's bluetooth, if it's still failing, try and re-pair the remote, or pop the battery tray out, and watch the LCD screen on the remote until it's done rebooting.
You can also use it for other TV functions, check if that's working.
