Few points, what settings did you use to reproduce those issues?
If you've got the backlight/brightness amped way up, those results are to be expected.
If however, your backlight is around 8, and the brightness is around 45, and you can still see it like that, the panel has issues.
As suggested many times in this thread, a backlight of 8 or so, with the use of the eco sensor really makes a huge difference.
What most people don't realize is with the use of high intensity LED's, a backlight level of 8, is nearly equal to 14~16 on a panel with a different backlight system.
It would also be suggested, that you try another source of material to produce the grey screen. The AVS 709 disc is a great resource for test patterns.
