AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Official Samsung UNXXD7000 Owners' Thread
Official Samsung UNXXD7000 Owners' Thread - Page 107
post #3181 of 3244
Originally Posted by AtomicAgeZombie View Post
What are your settings?
Out of the box, factory setup. Video mode is on Nature or standard.
post #3182 of 3244
The out of the box settings are pretty bright, you should give some of the settings earlier in the thread a try. If you don't feel like doing that, just turn the backlight down to 8-10.
post #3183 of 3244
A few things. You are posting in the D7000 thread, which was the 2011 model, when you clearly have 2012 model. You will have better luck posting in the correct thread.
Secondly, you have a ton of apparently flashlighting and backlight inconsistency. However, this can be significantly improved with some reasonable settings.
Put your set on standard mode, turn the backlight down to 10-12, and set your brightness at 45. Color should be 47-50, sharpness 10-20. AMP to clear. You can fine tune from there, but let us know how the backlighting looks.
post #3184 of 3244
I appreciate the help, i will try these settings tonight. Sorry about posting in the wrong area.
post #3185 of 3244
UPDATE 2012-11-10: I called Samsung support back since they never called me back like they said that they would last week... I got someone in the US this time, at least she was a native English speaker (unlike last time). She was very helpful and verified that my Samsung Gusto cell phone should have been able to detect the TV's bluetooth. I wasn't sure if it would since it is a bottom end model phone. She arranged for a tech to come out to the house to check the TV. She even told me that it will be considered under warranty until Jan 2013, even though I bought the TV at the end of Nov 2011. I'll update again once the tech has been here.
When I had the tech come service my D8000, he noted that the bluetooth modules commonly fail and pointed out the location to me should mine fail out of warranty. It is super easy to replace if you are out of warranty and can buy one online.
Thanks, that's good to know. I guess I'll start searching for replacement guides and modules.
Edited by yabbadabbadont - 11/10/12 at 7:52am
post #3186 of 3244
noticed while watching nfl today, 1080i, even in clear AMP mode, the game still goes in 'slow motion' at times.
any way to fix this or is this a common problem that plagues this tv?
post #3187 of 3244
Just throwing out a few possibilities....
You sure it's the TV? Does it happen on all channels showing games?
Perhaps it's broadcast signal is in 720p?
Does it happen on a Blu-ray that has some fast action scenes?
post #3188 of 3244
I have had the same issues with the D7000 with live TV and Blu-ray. I approached Samsung on this and a couple of other issues. Long story short, no answer on the AMP jerkiness/stuttering. I was told to put the TV into game mode. Doing so does stop the processing, but it also lowers the resolution. They did, however, offer to send a tech out to look at what is happening, but that is tough for live TV.
I gave Samsung an expert's opinion of what is causing the problem, but no acknowledgement or indication that it will be fixed. This problem goes back several models and people keep asking Samsung to fix it. It also seems to be present even in new models.
The problem as I understand it is that the auto motion plus kicks in randomly despite having it turned off or even in clear which I use. There is some sort of threshold that makes this happen. An engineer that posted in the SammyGo forum found that changing to a specific model eliminated the problem, and that the poster was working on it to see if there was another possibility, but that has yet to happen.
There is another thread going called "Samsung Auto Motion Plus not HD compatible." You might to to go through that thread and read some of the comments.
It's truly sad that Samsung has no respect for its purchasers when a problem has been ongoing for quite some time.
post #3189 of 3244
Have you updated the firmware of your tv?, if yes then that's the cause. I used to have a Samsung es6500 and before the update, the AMP was clear with no stuttering, but once I updated, every signal, even 60Hz signal had stuttering/jerkiness, and images were blurry. I returned the TV, and I'm in search for a new one without those issues. I recommend NEVER UPDATE THE FIRMWARE UNLESS YOU ARE HAVING THE ISSUES THAT THE UPDATE RESOLVES. Firmware updates focus only in resolving bugs/issues, THEY NEVER ADD FUNCTIONALITIES OR NEW FEATURES.
post #3190 of 3244
Yes. In fact the Samsung service individual asked me if I had up-dated the firmware. I was told that there were changes made to help with the AMP issue. I responded by sending a copy of what is on the web site with the improvements listed and advised the individual that there was no mention of changes for the AMP, just a series of generic changes that have been pretty much on most of the up-dates to that point.
Unfortunately, some of the up-dates tie directly to things like Netflix and MLB in the SmartHub and not much else.
The only good news is that the picture quality itself has remained consistently good unlike the problems with the new ES series in which picture quality became poorer after recent firmware up-dates. Samsung actual;ly acknowledged the problem in one series and is working on a firmware fix. Imagine that!
It seems like no one talks to each other at Samsung when they work on the firmware up-dates. It is a hit and miss situation, and to top it off, their service people have no clue what are in the firmware updates.
All my other TV's are Sony's and I never, ever had a problems with firmware or the stuttering/jerkiness.
post #3191 of 3244
I'm not that old, but I learned a long time ago to not update firmware unless I was having problems. And even then it is debatable wink.gif
post #3192 of 3244
I'm afraid that for some reason I'm one of those that can't seem to resist an upgrade. So far it hasn't bitten me but I'm going to make an effort to avoid future upgrades for this panel unless it addresses something I'm looking for!
post #3193 of 3244
Searching a bunch of blogs, I found something interesting. Someone suggested that you need to turn on the AMP, go to custom and set both sliders to 0. The comment was that you had to turn it to turn it off.
I tried it last last night. Watched some live basketball and football and it seemed to me to be a bit better than using clear.
post #3194 of 3244
Hi Nitra,
Just bought Samsung UN65ES800 , they are trying to sell me Calibration package.
My question, is it something I can do or I should buy it!
Many Thanks
post #3195 of 3244
Originally Posted by Samsung UN65ES View Post
Hi Nitra,
Many Thanks
You might find more help in the ES8000 thread but FWIW you can try some of the settings given in that thread or buy a calibration disc and try it yourself.
Nitra posts in the 8000 thread also.
post #3196 of 3244
post #3197 of 3244
Hi.
I have this LED- UN60D7000 that have the regular micro dimming algorithm.
I heard that i can change thru technician menu that this TV will be UN60D8000 that have the better micro dimming algorithm(micro dimming plus)
Is this true?
post #3198 of 3244
Originally Posted by yuria View Post
Hi.
Is this true?
Very interesting. I'd love to hear if this is true and then how one would execute it.
post #3199 of 3244
Hi.
Is this true?
I dunno...I believe there's hardware involved with the micro dimming so I have my doubts.
post #3200 of 3244
Hi guys! I'm new to this thread but just have a couple of questions. When I first got my D7000 in April, it stayed connected to the internet and logged in at all times. Then our internet went out once and it wouldn't keep me logged in. Not a big deal. Now I moved and it won't stay connected to the internet or keep me logged in. Every time I turn the tv on, I have to reconnect to the internet. For someone like me, who watches a lot of Netflix and uses Vudu a lot, it's quite annoying. Any suggestions? I've searched near and far, to the depths of the sea and have found nothing but a couple of BS suggestions. Thanks!!
post #3201 of 3244
post #3202 of 3244
post #3203 of 3244
post #3204 of 3244
When i upgrade the firmware of my PN60D7000 to ver1026.0,
i notice that i must set the brightness level to 72 (at cinema mode)
insted of level 46 before the firmware upgrade at the same condition and the same calibration video
What is the problem with new firmware ver 1026.0?
Is someone having this problem after updating the firmware?
post #3205 of 3244
so anybody got a new setting setting for playing xbox or ps3 they would like to share or a setting you guys pretty much settled, i have one for some reason i wanna try what others got lol
post #3206 of 3244
Power was lost during the second stage of a firmware upgrade when it's flashing the new firmware to the samsung mainboard. Now TV is bricked.
- Is it recoverable? Is there a debug tool to reflash the firmware
- Most likely firmware failure not covered under extended warranty I currently have. Will a samsung technician be able to know that the TV was bricked because of fail firmware flash?
Thx
post #3207 of 3244
Thx
Call samsung and play dumb. Just say the screen said a FW update was available, it did its thing, but never turned back on. when you turned it on.... ~bRick~
post #3208 of 3244
Surely all the folks who have read and kept up with this thread know by now the debt of gratitude we owe Droozy. Thank you sir - yet another brilliant post by you!
Andre'
post #3209 of 3244
Anyone having trouble with the internet connection on this tv? (I actually have a D7050). Apps are really slow, youtube and browser app aren't opening. Maybe a maintenance?, please help!
post #3210 of 3244
Wired or wireless connection? I had problems with my wireless connection so I switched to wired. It seems "sluggish" at times.
