AVS › AVS Forum › Audio › DIY Speakers and Subs › Torq on bolts with sub.
post #1 of 9
Hey,
I was just wondering how much torq you should apply when installing a driver for a sub.
I'm using baltic birch with tnuts and hex bolts. Like this:
I want to tighten them, but not strip them and have the fear of the t-nut coming loose. I installed them with liquid nails to increase their grab, but I'm worried I could tighten them too much and cause them to spin. I have a torq wrench with hex bolt attachment.
post #2 of 9
You will be able to "feel" when they are tight enough. It does not take a bunch of torque, just enough to compress the gasket some. To make it easier, try and use a nut driver as opposed to a wrench which could over-torque the nuts/screws.
post #3 of 9
Another thing you can do if you have left over wood is test it. See how pressure it takes till your happy or till it gives.
post #4 of 9
I used my drill set to 5, just 1 under the max. I then tightened a bit more by hand. I thought with a torq wrench I could measure the pressure precisely for each bolt.. The gasket has compressed a fair amount, so it may be sufficiently tightened, but I thought there may be a standard gauge for it.
post #5 of 9
Don't rely on a torque wrench. You need to do this by feel. Those t-nuts are cheaply made and often bind up.
post #6 of 9
You are probably good. If you see the metal "frame" of the driver start to deform you have gone too far.
post #7 of 9
This is a big driver, so I don't think I'll see it deform, but I'll keep an eye on it.
post #8 of 9
Put all the bolts in first, use the star patten, no need to over tighten Go around in the star patten tightening alittle each time, it should take 3 or 4 times.
If you see or hear something, its than to late..
Its all in the ""feel""
post #9 of 9
Well it's tightened and tested the sub tonight. All is well, thanks.
Will post build pictures in a new thread later. Test through the weekend and then stain.
