Originally Posted by
tiny0011
I found this on the 707 thread.
How to store and recall all settings.
All operations are done from the front panel, not the remote.
To store:
1.Push and hold setup on the avr.
2.Then push enter.
3.unit displays setup store.
4.Still holding setup, push enter again.
5.Unit displays setup storing.
6.Unit then displays complete.
All audessy,tuner presets,input names,intelli volume and power on level are stored.
To recall:
1. push and hold setup on avr.
2.Then push return.
3.Unit displays setup recall ?
4. Still holding setup, push return again.
5.Unit displays setup recalling.
avr will go into standby mode.
I had to use this feature once and it works!
Remember if you change any settings rerun store program.
This sure beats having to reenter everything again.
