Originally Posted by Tollster
Hi ya'll, glad I found so much knowledge on this new unit. I am very happy with my NR-509, mostly since I can hook up my HD and listen to my MP3's.
But this is my second 509 in less than a week, now it is showing the same issues as the last one and wondered if anyone else has trouble.
HDMI Game port connected to a sony PS3, some times more often than not, when I boot the PS3, the sceen never shows that its connected, only a blue screen exists. Other times I hear the sound, but no video image, then sometimes it works.
I thought it may be the cable, and have ruled that out by connecting to the HDMI on the TV, I also tried the other ports on the Av unit with no issues.
The game port worked for a day or so, so I am wondering (hoping) if perhaps its in the set up? I have done a reset, but to no avail. I am currently doing a USB jumpdrive firmware update.
Anything ya'll may suggest would be a great help.
Thank you,
Tol
Thank you,
Tol
In I/O assign, what is your Monitor Resolution setting? Auto? Are you using your ps3 for BR or Games? For fault finding, try BR and fix your Res at 1080p/24 and see if your hdmi handshaking issues disappear. Assuming your tv can handle this one. Else if your games are 720p, fix to this.
