Originally Posted by Scotty9er
I've had the NX509 for about a year now and love it. I have a question regarding speaker configuration I am hoping somebody on here can help me with. Up until now, I have had two front speakers, two surround speakers and 1 SW, and have only used the receiver for streaming Pandora. Over the holidays I got myself a newer tv finally, as well as a new center speaker. The TV and the center speaker are in an entertainment center cabinet. So my question is, is there an easy way to set it up so that when I am listening in Music Listening Mode to have the center speaker disabled (because it is behind the cabinet doors), and when I am listening in Movie Listening Mode to have it enabled (because the cabinet at that time is open to watch the tv). From what I've seen so far in playing with the settings, the speaker configuration is a global setting, so setting center speaker to 'none' disables it across the board. The closest I have gotten to my desired result is to have music listening mode be in 2.1 and the movie listening mode be in 5.1. Please advise. Thanks!
No, you setup the Center and leave it alone.
Right, you use Listening Modes. There is Stereo and others that don't use the Center. You can select them manually or assign them to be used when a Stereo source is detected.
The owner's manual explains how to use Zone 2 - it's fairly straightforward.
