AVS › AVS Forum › Other Areas of Interest › Camcorders › My Official Sony HDRCX 560 Review thread
post #1 of 306
I just picked up the new Sony HDRCX 560V Camcorder at my local Best Buy. And is it improved over the older 550V. I will be posting my thoughts soon.
post #2 of 306
With videos I hope!
post #3 of 306
Can you have all three exposure parameters - aperture, shutter speed and gain - locked at the same time? Or at least aperture and shutter speed, assuming that gain is linked to one of these? Ken says no, but double-checking this would not hurt.
post #4 of 306
Best Buy does have the CX560 in stock so I am going down there tonight with a small 2GB card and take a couple of videos to compare it to the TM900 that is coming in tomorrow.
Any particular tests that anyone wants me to test for while I am there?
post #5 of 306
Compare CX700 vs TM900. Not CX560 vs TM900.
post #6 of 306
Do you think it's okay with Best Buy if you bring in your old camcorder and test the OIS? You'd have to hold the 2 camcorders together as if they're glued together and then pretend to have shaky hands, but move them simultaneously.
Then, of course, post the videos for us. This can be useful. Thanks.
post #7 of 306
Isn't it pretty much the same thing with the exception of 32 gigs of flash and a view finder? I see no reason why you can't compare it.
post #8 of 306
This little video is right out of the camcorder and uploaded to YouTube.
One thing I quickly noticed was the 560V is a much smaller package then my 550V.
http://www.youtube.com/watch?v=lQF80REiKFM
post #9 of 306
Can I ask if this footage was shot and uploaded with the cam set on it's highest bitrate? The 1080/60p bitrate? tia
post #10 of 306
Auto mode was used.
post #11 of 306
This is a pretty good video for checking stuff. Blades of grass require good detail recorded, and they look pretty good. But, on the last zoom in tight the camera lost focus. This has been a problem in my experience with Sony cameras in video - losing focus (and then recovering) during a zoom.
I like the audio with the birds and windchimes(?), but there is wind rumble - did you try wind suppression?
Again, what quality video is this 108060p? or 108060i, what bitrate?
post #12 of 306
Well then yoou will have to wait a month or two until Best Buy has the CX700 in stock, if they ever even carry it. There is no difference between the CX700 and the CX560 except for the useless 4:3 aspect ratio on the EVF and an additional 32GB of internal memory.
post #13 of 306
Well Best Buy was not happy as they had to open up a new one sealed in the box for me to test. They don't have a demo unit yet.
I used all the settings out of the box except for using the memory card which i formatted and setting it to 60p.
I was really unimpressed with the 1:30 of video I have also I think it's 60i footage, but the battery was low and the Best Buy guy was less than helpful. I did a low light test but everything was done in 5 mins from open box to me ejecting the SD card.
I also don't like how the SD card put into my PS3 resets the PS3 everytime I watch it.
Low light isn't all that great in this video and I went into their entertainment room which is very low light. I also found the focus to be quite slow.
I'd upload the video but it's done very fast and looks like crap.
I did capture the Best Buy guy's sour look for posterity. He clearly did not want to use a new camera to do this.
post #14 of 306
I just noticed the wind noise reduction was turned off.
I have looked through the menus and I don't find any setting for 60p or 60i
The cinematic quality video mode was not on, is this what you are referring to?
post #15 of 306
These are the video modes: HD PS: Approx. 28Mbps / FX: Approx. 24Mbps / FH: Approx. 17Mbps / HQ: Approx. 9Mbps / LP: Approx. 5Mbps; STD HQ: 9Mbps
Which one were you using?
post #16 of 306
The CX700V product manual is available at the Sony support page
http://esupport.sony.com/US/perl/mod...0V&region_id=1
To select 60p mode (pg 87 of product manual), Touch [MENU] -> [Image Quality/Size] -> [Frame Rate] -> 60p. Remember to confirm the selection by touching several next buttons.
CX560V also lacks Expanded Focus, Zebra and Peaking according to the manual (pg 85 - 86)
post #17 of 306
to use 60p, touch [MENU] -> [Image Quality/Size] -> [Frame Rate] -> 60p.
Then touch [MENU] -> [Image Quality/Size] -> [REC Mode] -> [60p Quality PS]
post #18 of 306
CX560 is same as CX550
CX700 is different from CX550
CX700=0 lux
CX560,CX550=3 lux
CX700=jpeg 12.3Megapixel
CX560, CX550=jpeg 12 megapixel
http://www.bhphotovideo.com/bnh/cont...G%3B748433-REG
post #19 of 306
Thank you. Modes were standard except 60p was set. Now I have them set for high quality.
post #20 of 306
Default setting is Standard mode [HQ] (AVC HD 9M (HQ)) and 60i if u didn't change any setting. Maybe that's why it looks like crap.
post #21 of 306
I did change the setting to 60p and the highest mode and memory card but none of the other settings.
post #22 of 306
I hear the background noise that's also my .... cx560 is a little defect in this series, perhaps
post #23 of 306
I too went to check out the Sony cx560v today and what a sweet Cam it is. It really delivered low light quality at 60p and motion and focus was lock in and spot on. I took test shots with a Sandisk extreme 4g card and viewed it on my Sony XBR 1080p TV, through my playstation. Flawless I just couldn't believe the colors, they were so natural and realistic. I was able to shoot in natural light out in front of the store and in side in there high end Digital TV room too. I have already pre ordered the Canon HF g10, and am thinking about buying this in the summer as a second Cam for the wife when the prices drop off. I was not impressed at all with the Panasonic TM 900 though.
purplestinger
post #24 of 306
I had another listen just now to this video with my headphones, and I do hear what you are talking about now. Very strange...
post #25 of 306
post #26 of 306
CX700=0 lux
CX560,CX550=3 lux
no no
cx560 = cx700 quality video
post #27 of 306
So how are you liking it? Looking like a keeper so far or sort of a let down? Mine just arrived today but I probably won't even have time to open it tonight. Curious if it's worth it.
post #28 of 306
no no
Sony's 500 series different from Sony's 700 series
make a comparision on bh photo
post #29 of 306
B&H has inaccurate specs. For example, a difference you listed is the 700 has a 12.3 mp camera, but the 560 has only 12.0 based on B&H. That's wrong. On my box for the 560 it clearly says 12.3 mp.
The 560 and 700 are almost exactly the same except for a couple minor differences. They even have the same manual.
post #30 of 306
No. I believe only the upcoming Canon G10 can do that.
  Back to Forum: Camcorders
