AVS › AVS Forum › Other Areas of Interest › Camcorders › My Official Sony HDRCX 560 Review thread
My Official Sony HDRCX 560 Review thread - Page 11
post #301 of 306
I tested it outdoors and in better lighting conditions and it didn't have that same focus hunting. It was just reeeeaaalllyy slow focusing. I think I was just being anal about the camera, I tested it against my 550 and the focusing was about the same.
post #302 of 306
Good Luck hope you made the right decision as to getting it checked.
post #303 of 306
Has anyone found a decent lens hood for this camera? The ones i see out there aren't really compatible with the wide lens that this camera has.
Also has anyone mounted a microphone on theirs yet? If so which one did you get?
post #304 of 306
Hi. I'm just about ready to buy the CX560 from Amazon. I'd like to add a lens protection filter and a lens cover. Any recommendations? Thanks.
post #305 of 306
Any one find a hood for this camera? Its been months and no answer and no luck
post #306 of 306
Im using the camcorder in filming format and also taking photos whilst recording video. BUT i have noticed that when you take photos in the video mode the flash does not work..is there a solution/workrounhd for this situation_n The only way i have been able to use the flash for photos is by using the camcorder in camera mode...but you have to change the modes over manually....i need to use the camcorder with the remote and so dont have the possibility of switching modes BUT the photos *at dusk( are relly bad wiothout being able to use the flash. AAnybody else come across thsis_
  Back to Forum: Camcorders
