Just bought another one and I'm able to sync with my tv. I have to place the IR very close to my existing transmitter. Glasses are still charging so not sure the image quality. I'll find out in a few hr. You're right the 3.5mm jack has to be pushed in all the way and if it was left 3/4 in running lights turn off. Why can't they make the jack much better?
What I found is that the lenses need to be as parallel as possible to the screen and your eye's viewing path as perpendicular to the lenses for optimum ghosting and color performance. I was somewhat 'reclining' in my seat and as the lens became less parallel to the screen the ghosting increases. This sucks for using a recliner...so I tilted the frames downward a bit...the frame handles lifted off my ears...but the ghosting decreases and disappears. However the other artifact is that the picture darkens a bit (with a somewhat green tint.) This I attribute to my eye's viewing angle now hitting the lens at a less than perpendicular angle causing more light loss/polarization.
