Originally Posted by
Ronomy
Minimum would completely shut the lenses off. Try 50% duty cycle first. That worked for me.
Just for my clarification:
1.
With the DEFAULT emitter settings, I FIRST press and hold the joystick (menu 2 of course) to the left until the orange leds are approx in the middle.
2.
After this I reduce the deplay to MINIMUM by pressing and holding DOWN the joystick until I have 0 (red) leds.
3.
From that point I raise the joystick UPWARDS until I see the least ghosting.
4.
After this I raise the brighness (joystick to the RIGHT) until ghosting start to re-appear and when this happens I put it a little back to the LEFT until I have no ghosting again.
Is this the correct procedure?
