Originally Posted by sanderdvd
What is the way to config the DELAY+LENS DUTY CYCLE to accomplish to best result? (for your info, I m sensitive to ghosting so I prefer the least ghosting).
Changing the delay is the thing I don t understand. When beginning from 20 and moving the delay upwards it looks like 'the same result is repeating itself for a few times' untill 45000 (max) is reached. I hope you guys understand what I mean here. So what is the best to choose here?
Thxz!
Thxz!
I can't speak with authority (I've only owned them for 2 weeks), but what your seeing is changes in polarity (as you adjust from one lens to the other) and an increase/decrease of the 3D effect. Find a 3D scene where you know something should be coming out of the screen or at least more pronounced in the foreground. Adjust the red lights until you get maximum 3D effect. Then go back to a menu screen and adjust the orange lights until you get the image bright enough without seeing any ghosting. You may have to do this process one more time after double checking the previous image. If it looks blurry, then you can adjust the red lights until the image appears sharper, at the expense of a lesser 3D effect.
Of course, if any of the experts wish to chime in I have no problem being corrected as I'm interested myself.
