Originally Posted by nareciss
Hello everyone,
First sorry for my bad english but i ll try to explain myself the best i can.I recently purchase a 3d vison max kit to try it with my panasonic vt 50 plasma,first i upgrade the emitter then charge the glasses and put it to work.
But when the glasses try to connect to the emitter i have a very dark picture and the 3d effect don't work.I try different setting (bluray disc and mkv sbs file) but neither of them work.
Do you think something is broken in my kit or it could a problem with inteference with something elses,or just not compatible with my tv.
thanks for helping me.
Hello everyone,
To use the Max 3D setup, your VT50 has to have either a VESA 3D connector (this looks like a PC mouse or S-video port), or use IR to trigger its glasses. According to the user manual on the Panasonic website, the VT50 doesn't have a VESA 3D connector and uses Bluetooth to run its glasses. The Max3D is RF, but not Bluetooth. Sorry, but I think you're out of luck and should probably return them and get the Panasonic glasses.
