AVS › AVS Forum › Other Areas of Interest › Camcorders › Canon HF G10, XA10, XF100, XF105 Owners Thread
Canon HF G10, XA10, XF100, XF105 Owners Thread - Page 139
post #4141 of 4142
Originally Posted by MikeekiM View Post
That said, am I better off with 60i in a 60i container, or PF30 in a 60i container?
No reason to shoot PF30 if you want to treat it as interlaced. Treated as progressive PF30 gives you twice higher spatial resolution with twice lower temporal resolution.
60p would be the best choice if low-light was not a consideration - you can make it into 30p or 60i. Still with 60p you would have to use 1/60 shutter to get 60 different frames just like with 60i, and if you use 1/30 it will be no different than 30p because two consecutive frames will be identical.
post #4142 of 4142
60p isn't an option though... Canon only has 60i, PF30, PF24 and 24p (the first three stored in a 60i container)... Right?
  Back to Forum: Camcorders
