1st of all, since you have problems already,
I would not complicate things by choosing dxva decoders - they can fail to decode when the files are 'out of spec'
For M2TS playback in the Microsoft players
SWAP TAB, disable Media Foundation / disable Microsoft Audio decoder (to allow bitstreaming)
MPG~MP4 TAB, select the bluray splitter
maybe this command will help in your situation.
Open a command prompt using 'Run as administrator', type the following, and then press enter
Lodctr /r
Lodctr /r
