AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › The Little Theater That Could - Start to Almost Finished
post #1 of 69
March 2013 update. Projector died yesterday and I have been tearing my "finished" room to pieces installing some serious bass. See end of thread for gory details.
The Small Room: 13' X 14' with 8' ceilings in the corner of my basement. Obstacles include ducting and a support beam along one side, electrical and water access in one corner and 16 feet of narrow windows along two sides.
The Equipment: Some old, some new.
- Receiver: Pioneer VSX-919 ($385) 7.1 receiver
- Speakers: Camber 3.5ti fronts & center ($1200), Mission surrounds ($35 garage sale).
- Subwoofer: Quasi-moto mix of 2X12" car subs driven by a vintage Kenwood amp. $400
- Source: PS3 ($300)
- Screen - White over silver Spandex acoustically transparent - constant area 112" wide ($100)
- Projector: Acer 5360 ($580) (Died of fan failure March 22, 2013 RIP)
Total equipment - $3000 purchased over the last 15 years.
Total room construction with acoustical treatment - $1500.
Total theater cost - $4500
The Setup:
Viewing distance - 9.5 feet.
Projector - 14 feet using a mirror to gain the required throw distance.
Edited by DavidK442 - 3/23/13 at 4:52am
post #2 of 69
The middle row of Pot lights are on and dimmed during movies. The lights are small and located deep inside the can so there is no direct light hitting your eyes. Also, because they are pushed right up against the 10" drop ceiling there is no direct light landing on the screen wall. The two Pots in front shine on the bank of drawers and equipment shelves along the front below the screen.
post #3 of 69
The room is narrow. 13 feet isn't much to work with, especially when 2 feet is taken up by cabinets and the neighboring bedroom's closet.
post #4 of 69
I left the bulk head over the cabinets open and filled it with 6" Rocksol to act as a bass trap. Due to the small room the seating is pushed up against the walls. To reduce behind head reflections the drywall was left off between the studs on the South and West walls.
post #5 of 69
This shows the corner bass trap taking shape. The electrical panel and water shutoff were a royal pain but are now neatly hidden behind hinged doors. The reclining sofa is a hand me down from the in-laws. Light colored and ugly but very comfortable. For now it stays, as does the light colored laminate floor.
post #6 of 69
A better shot of the corner which became a bass trap. Trying to make an integrated installation that was reasonably symetrical with the other half of the room was not easy.
post #7 of 69
Here is the bass trap in the opposite corner. Building the traps out away from the wall allowed me to run a 14 inch shelf between them underneath the window. Should make a good home for the projector. The window covers are 1/4 mdf sheets in slides.
post #8 of 69
Out of build sequence but here is a better shot of the bulkhead above the screen. Both areas, behind and in front of the support beam were filled with insulation to act as a bass trap. I had contemplated filling the entire area behind the screen (8' wide X 5' high x 14" deep) with insulation to also aid in bass absorption but after hanging a quilt across this area found that the room became too acousticaly dead. Will maybe just add corner traps beside my front speakers instead. I've seen many home theaters with the walls covered in acoustic panels floor to ceiling with thick carpets on the floor so I was suprised how aweful a little more absorption sounded in my room. Every setup is different I suppose.
post #9 of 69
DavidK442,
Your room is looking great! Keep up the awesome work. I too have a small theater build in the works. My room dimentions are 11X13.
post #10 of 69
Hey another BC'er, Welcome! I'm really impressed with all the work you have done so far. The progress looks good so far. I can't wait to see the outcome, keep us posted with your progress, thanks for sharing.
post #11 of 69
Looks really nice and cozy so far! Saving for the RS-40 should make you really happy, it will be plenty bright on a 106" screen!
post #12 of 69
Nice stuff. Great to see a creative approach to a small room with lots of obstacles. Keep at it. Dimensions are similar to the room I bailed on and turned into a gym. Makes me think what could have been. . . .
Make sure you add your thread to the small builds thread (linked in the "show me" sticky).
post #13 of 69
Rail and style frames wrapped in black speaker cloth cover the bass traps and sound absorbers, held in place by wood trim.
post #14 of 69
Very nice room! It's only slightly larger than mine but I dig the color choices.
Victor
post #15 of 69
I removed the drivers and cross-over from my side and rear surround speakers and built enclosures to angle them down from the wall/ceiling junction. The angles are different, with the rears more steeply sloped than the sides. I used speaker grill snaps but should have gone with velcro as they turned out to be a bit flimsy.
post #16 of 69
How did you go about blacking out your window?
post #17 of 69
The front main speakers were built into custom cabinets like the surrounds. The baffles were angled 35 degrees to cross fire for better imaging. This also allowed me to make the cabinets an inch narrower which was necessary to fit a 106" screen between them. You can just see the velvet covered frame I built to reduce reflections on the ceiling immediately over the screen while allowing good air exchange for the bass trap above.
post #18 of 69
Awesome build, I really like the way the woodwork came out and the way you mounted your speakers. Now dump that horrid in-law handme down couch!
post #19 of 69
I think the couch looks very comfy, assuming at least the ends recline. And once the lights go out to watch a movie, who notices the color of the couch?
Well done. Looks very nice, IMO.
post #20 of 69
Looks great especially for the small space. Really like how you integrated your speakers. B.C. is one of my favorite places. I've spent some time up there, but it has been a while since i have been up there and I'd like to get up there soon.
post #21 of 69
The airport in Salt Lake City leaves a lot to be desired. When I was living up there people were always telling me how beautiful Utah was. I was always surprised since to me BC is so beautiful.
There are some really fantastic sights in Utah - but without question the most beautiful place I have ever been is up near Whistler on a hike to Garibaldi Lake. We hiked up to the top of a mountain overlooking Garibaldi Lake and it was an incredible sight.
post #22 of 69
The screen is an Accuscreen 106" acoustically transparent. Assembled easily and no visible weave at about 7 feet.
post #23 of 69
Looks really nice - the woodwork turned out great - What projector are you considering?
post #24 of 69
Good looking room. Love the color choices and the angled closures for the side and rear speakers....almost done.
post #25 of 69
Looks great! I like the timber trim.
How does the surround sound sitting right up against the wall?
post #26 of 69
Looking really good, the trim really works well with the black.
post #27 of 69
My thinking exactly which leads me to ask...what color stain did you use?
post #28 of 69
Did you say you could live with the image not fitting the screen?!?! Please tell me your joking... Are you going to build a masking system?? That would drive me crazy.
post #29 of 69
Sansui AU11000a Integrated
Kenwood KA-9100 Integrated
Pioneer SA-8800 Integrated and TX-7800 Tuner
Sony TA-5A Integrated and ST-A3A Tuner
Kenwood KA-5700 Integrated and Pioneer SA-7500II Integrated
Pioneer, Harmon Kardon and Marantz Receivers
(I drag the Pioneer out along with a pair of Paradigm Titan bookshelves for outdoors movie night.)
post #30 of 69
