AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Samsung PNxxD450/PNxxD490 Owners Thread
Samsung PNxxD450/PNxxD490 Owners Thread - Page 4
post #91 of 1832
that sounds pretty good! its our bedroom tv like i said so its not like we're going to be doing any crazy content watching, but as blu-ray player prices fall etc, im sure i will add one to it in the future. i do like that i gain the 1 extra inch without increasing cabinet size either, so i hope what i see is great!
post #92 of 1832
The BD-C5500 is only 98 bucks on walmart.com Idk if Im supposed to be advertising like that, but a good blu ray player is hovering right around 100 bucks nowadays. Thats why I finally went out and got one.
post #93 of 1832
Originally Posted by eckohb View Post
There is some reflection, I have four windows in my living room, and there is reflection, but ive learned to live with it. Its not the end of the world, considering I got an awesome TV and a Blu Ray player, with blu rays, all for the price of my flashlighting LED-LCD I exchanged for the D450. Im not sure how the C450 is in comparison, but I would just go with the D450, as a lotta of owners had buzzing problems with the C450, and I really dont hear any buzzing at all unless I mute the tv and put my ear right next to it. Plus, you will appreciate the Plus 1 design with the 43". It's well worth it
Agreed.
However, in this case, they should've called it 'Plus 0.7' (42.3" to 43")
post #94 of 1832
Originally Posted by tripod39 View Post
Never had a 720 set (D450) before,always 1080.Should I reset my cable box output to 720p or leave it at 1080i.Will run BR today to compare to 1080.
Ran "Three Days" blue ray today.Very good,big improvement over upconvert dvd player.Not as good as but very close to.
post #95 of 1832
QZ1, I saw your posts regarding the resolution of the TV. I suggested 720p was better because that's what my cable box automatically set it to. My blu ray player automatically detects 1080p, as well as my xbox 360, and the picture looks phenomenal. Im not to familiar with upconversion or anything like that, I just know I cant tell the difference between 1080p and 720p. This picture actually looks better than the 1080p lcd I previously had.
post #96 of 1832
Well, the cable box could be set to output 720p or 1080i (not 1080p). To be fair, one would need to look at a 1080i channel and a 720p channel on the 1080i setting, and then the same two channels on the 720p setting; total of four tests. You might be sitting far enough back and/or you visual acuity isn't 'eagle eye', such that it doesn't matter. If your cable box can do 'native passthrough' that would be best, of course.
post #97 of 1832
Ok, I now have noticed a bit of an annoying problem with my set. I guess I did not notice it much until I put in a few titles with some more vibrant colors/brightness. I notice that the brightness tends to fluctuate quite a bit. Yes, the Eco settings have been turned to off etc. It is quite annoying especially when wathcing Despecible Me and the Tahti 3d Blu-Rays. It does go away when I drop the contrast way down to about 50, but that makes the transfer way too dark to fully enjoy 3D.
post #98 of 1832
I'm experiencing some buzzin with my D450..
I don't know if its my ear too good or is the TV making too loud buzzin..
post #99 of 1832
I tried going to display settings, and it looks like there is no way to change the output on the box. It must output automatically. I've got 20/20 vision, and trust me, I look for things to be wrong lol. My gf tells me something is wrong with me because I did that with the LCD and found the flashlighting/clouding on both sets I previously had. Thats why Im so impressed with this TV, because I cant even find anything wrong with it besides only having 2 HDMI inputs. But even component cables have my cable looking good.
Also, I set my blu ray to 1080p and 24fps, and there was no judder and the picture quality was better than 720p at 60 or whatever the standard is. Idk, either way, this is a great entry level plasma.
post #100 of 1832
Thats weird. Is it when the tv is on a certain source, or is it all the time? Do you hear it when the volume is up, or only when its muted?
post #101 of 1832
Unfortunately, Im not familiar with the 3D part of the D490. I dont experience fluctuating brightness with the TV itself, only with the brightness level of my living room throughout the day. Im not sure where you got the TV, but its always worth a shot to exchange it if youre not satisfied.
post #102 of 1832
Usually the ability to change the output is not in the "user" menu, but in the service menu. If you are unsure, Google your model and service menu and see what you can find. I would be very surprised if you didn't have the "native or "pass-through" option or the very least be able to set 720P or 1080i on the box.
post #103 of 1832
^^ That is what I am going to do. I may go ahead and get on of the bigger ones since I am now hooked.
post #104 of 1832
what is the difference between native and/or pass-through? ive got a motorola, ill take a look and see what i can find
post #105 of 1832
There is no difference. It's just what certain manufacturer's call it. Either one does not do anything to the incoming signal but sends to the TV and lets it do any conversion necessary. On my Moto box you access it by turning off the box and pressing the menu button on the box.
post #106 of 1832
hear it when the volume is very low.. it come with any source, I tried from any source and even tried a dedicated power supply, not a parallel source. The more contrast it give more buzzing...
post #107 of 1832
I have an Atlanta Scientific cable box.W/remote,I select,under box settings,in video section I can choose any of 4 settings of which I pick 480p,720p,1080i and leave 480i out.As I change channels my box screen shows what output the channel I selected is putting out.It changes automatically for ea channel.Could be your brand of box isnt set up like mine.
post #108 of 1832
I forgot to even look at my model number. I went to display settings, and it doesnt offer those options like yours. My box shows what the display is, and its always 720p for HD content, and 480i for SD. Im going to have to try to look online for the service menu when I get home from work today
post #109 of 1832
BTW scratch my settings I'm red/green color blind..lol
post #110 of 1832
Are you using the ferrite cores that shipped with the TV? I don't have any buzz on mine.
post #111 of 1832
Originally Posted by Alex V View Post
Hey I'll post my settings. I'm not a calibrator so these might not be the best but anyway, I'm using this now :
Mode: Movie
Cell Lighting: 13
Contrast: 89
Brightness:35
Sharpness:40
Color:56
Tint:50/50
That's odd, my Cell Lighting only goes to 10 and I have the PN43D450.
post #112 of 1832
@ Lupik : I just tested 3 filetypes @d450, avi mkv and mp4. They all work. Also support for music and pictures.
How did you get .AVI movie files to play? On my D450 it only shows options for photos and music through "media play".
post #113 of 1832
He has a European model
post #114 of 1832
I picked one of these up today to replace an older Panny Plasma in bedroom. I hear this buzzing also on all sources. It is not like the directional buzz from last year's C models. I can hear this buzz on low volumes also 2 or above in any mode, any contrast setting. Was going to break this in an do a calibration, once a buzzer always a buzzer. Bringing this back to the store tonight.
post #115 of 1832
Just hooked up a harddisk to it. Then just go to the file and enter it.
post #116 of 1832
Just had a techie come in for the "buzz". He opened it up looked at it, fiddled with it until it didn't start up at first anymore. Then closed it back up. Those isolation pillows didn't help even a bit so he left them off. He did a soundcheck measured at 30dB . He didn't know if it was inside of limits but he thought it was annoying too at low volume.
It was the powersupply as expected. Btw, my set is made in Hungary...
Funny thing is that the c450 was right next to it, and it was way more silent than my d450 but he said you can't compare them because they are different models. So I guess going for a newer model justifies more noise!
Well anyway, I'm still happy with my set in terms of picture quality, but the buzzing is definitely a big con to go for this set. Peace out:P
post #117 of 1832
yeah I used that, anyway.. I will just try to get use with the noise.. haha and alternate way is to get a wireless headphone maybe.. haha.. anyway, still satisfy with the quality picture the TV produced.
post #118 of 1832
Can someone check in the picture settings menu possibly in the advanced settings for the D450 if it has a "RGB Only Mode" option.
post #119 of 1832
With a HDMI connect, the only thing I see with RGB is under white balance
post #120 of 1832
I have been trying to find out what the native resolution on the PN43D450 and PN43D490 are:
1280 x 720: 1366 x 768:
Samsung.com Logicbuy.com
abt.com
also, the previous posting about which res to set your Cable DVR for the best picture is also saying the tv is not true 720p. Just wondering if anybody knows what the true native resolution for these tvs. I'm talking about the 43", either the 450 or 490.
