post #1 of 1
I have the clarion 925vd TV with the 7'' display and have had a problem with the sound. Sometimes I will be driving, doesnt matter if its a cd or radio and the sound will just cut out. Everything is on and normal, counting up and nothing happens. I'll turn the volume up and no sound as well. Any ideas as to what is causing this? I will turn it off and then back on and it will then work ok, but usually cuts out again. I have had this unit for several years and have had to issues. Its installed in 2003 350z. thanks
