Originally Posted by
RubyT
Ok, I just got the s5400 and have been messing around for about 3 hrs last night. So far, everything seems to be working pretty well. The a/v sync from my cable box is slightly off. By the way it's slightly off on all my tv's. So it's not the s5400. I saw that the a/v sync on the s5400 only allows correction in 1 direction from 0 and up. I need to go in the other direction to minus 0. Does anyone know if I can do this on this with the onkyo receiver? Your comments are appreciated.
I've only had mine for a week now, and have the same sync issue...
Unfortunatlly, I know I can do nothing to solve...
In my case the TV audio content, either from stream or tuner from the TV goes right to the speaker and out of the optical OUT of the TV to the optical IN of the Receiver...
Obvious time delay sending out, and/or Receiver receiving...
Cann't go -msecs, if nothing is there, and I also can not tell my TV to slow up on sending to the TV speaker, so for now I just mute the TV (video/sound sync is unnoticable)...
For what is is worth, I do know the delay feature of the Receiver works, as increasing the +msec will make the echo worse...
Maybe someone will respond that has a TV with ARC(hdmi) capability and possibly the hdmi return channel does not have a delay...
