Originally Posted by robneal81
I have a Panasonic GT25 plasma TV and two pairs of X104's, each with the same problem: In order for them to sync properly, you have to start playing the movie BEFORE turning on the glasses or you'll need to re-sync them.
Also, one of the two almost always needs re-syncing every time, no matter when you turn them on.
Anything you do to break the sync will require a total re-sync, not just a power off/ power on. Some examples: If I leave the glasses on, walk into another room, then walk back, I'll have to re sync. Sometimes if I pause the movie and my Blu ray player's screen saver comes on, I'll also have to re-sync. It's pretty annoying.
This is the third brand of 3D glasses I've tried and they're still bar FAR the best. If I could get rid of the sync program and get them to be permanently set to my TV, they'd be perfect.
You might want to consider an IR extender.
http://www.amazon.com/s/ref=nb_sb_ss...ex%2Caps%2C184
It seems that your IR signal is not reaching the glasses.
