AVS › AVS Forum › Display Devices › Rear Projection Units › Sony KDL-46XBR2 Base Stand - Help please
post #1 of 3
Hi - I have a Sony KDL-46XBR2 that used to be mounted on the wall. I'm looking to sit it on a regular stand, but I don't have the base unit, so it won't stand up. (I bought it open box, so it didn't come with it). Sony does not have the part anymore (x21093092) - and I can't find it anywhere online.
Any thoughts on where I can get one? I found a listing on eBay for an XB6 (http://cgi.ebay.com/SONY-KDL46XBR6-L...7#ht_500wt_922) but not sure if it is compatible (the seller does not know either).
Any help would be appreciated! Thank you.
post #2 of 3
I am looking for the same base stand, did you ever find anything?
post #3 of 3
No luck. Wasn't able to find anything
  Back to Forum: Rear Projection Units
