I have an X-Rite i1Pro, REV D model.
Last night in a light and temperature controlled room I took a series of grayscale and chromaticity measurements:
1. After dark reading
2. After 1 hour
3. After 2 hours
4. After 3 hours
5. After 2nd dark reading
Other than for the initial measurements I took no further dark readings until after the "after 3 hours" reading. In the attached jpg file I found it unnecessary to display the "after 1 hour" and "after 2 hours" results as they are essential the same as the "after 3 hours" results.
I took a few random readings just to exercise the meter a bit after the initial reading until the "after 2 hours" reading. Because no differences appeared in the readings I thought perhaps meter usage might have an effect. Between the "after 2 hours" and "after 3 hours" reading I had the meter do continuous readings throughout the hour utilizing various patterns. The end result was still no change.
As a final step I took a second dark reading. The resulting readings were the same as the rest - no significant difference.
Is the REV D model different from earlier models? Why am I supposed to be taking dark readings if no difference in accuracy can be detected?
Why the term "dark reading" when it is actually accomplished on a white tile?
2. After 1 hour
3. After 2 hours
4. After 3 hours
