AVS › AVS Forum › Audio › Speakers › Dead Marantz Vintage speaker
post #1 of 3
Hi all!
I have a vintage Marantz 3 way speaker that just died. I've tested the impedance load at the speaker connector with a digital multi-meter, and it reads corrctly. However, no sound is produced when connected to amp (other speakers work when connected to this channel). Any suggestions?
post #2 of 3
Originally Posted by Lars Novas View Post
Hi all!
Pull the cross over and check for buldging or leaking or popped capacitors. Also check for burnt resistors (although if it's reading correctly at the connectors I doubt that is your problem). Check the soldered areas where the components connect to the board as well, you may find something came loose. Also check where the speaker connections connect to the crossover board.
Other than that, I recommend popping over to Audiokarma.org and asking there because all the old pros live there and one of them can probably tell you what is wrong and how to fix it.
post #3 of 3
2nd that... pull that Xover and replace bad caps, had to do the same on 3 sets of vintage KLH. Partsexpress.com dayton caps work just fine for the money.
  Back to Forum: Speakers
