Maybe integrate a matrix switch (2 simultaneous outputs) instead of a splitter into the path? May be easier to find one that handles 3d than a splitter.
I know the ps3 (which is software-based, maybe that's the difference) needs to be hooked up to the vip directly first, then you can move the vip further down the chain & the ps3 settings will stick.
Yeah, a firmware upgrade for the S580 would be the cleanest solution.
