Originally Posted by
Trevor JK
SO humour me. Which is best performance. Printer attached via ethernet cable or USB? Hard drive attached via ethernet cable or USB? Thanks in advance!
I don't think humor/humour is the proper word.
As for printer, that's the printer's problem, A printer with an IP address and/or CAT5 interface is usually more expensive than a USB driven printer these days. Remember when it was a serial or parallel/IEEE-488 issue? However, most networked printers provide a lot of status information for remote maintenance.
I know of no stand alone HDD with an internet/CAT5 interface so I can't help there.
A lot have USB ports though. With USB to HDD it is important to use that option of disconnect, since you can have buffered data loss if you simply pull the plug. A read-only USB device on the hub doesn't have that problem, but there is an option to "safely" remove the device on the router admin program.
For further humo(u)r, you could try google or bing.
