Originally Posted by
img eL
Bob Silver, when will the DGND3700 be released & what advantages will the WNDR4000 & the WNDR3800 have over the DGND3700? thanks
OK heard back from the Netgear Product guys. DGND3700 will be available next month. Initially in Frys and then through out the channels. This router is built on the 3700 platform with a couple exceptions.
DGND3700 offers:
- Highest Integration: ADSL2+ Modem+ Simultaneous Dual Band Wireless (2x2 2.4 & 5GHz)+ Readyshare Storage with two USB ports (3700 only has 1 USB port) + four Gigabit LAN ports
- Best Performance: Dual Core Processor to handle the most demanding applications
- Future-proof: Option to upgrade from ADSL to next generation high speed networks through the alternate Gbit WAN port to connect to Cable/Fiber Modem
- With Intelligent QOS, DLNA ready, Live Parental controls, Guest Wireless, Broadband Usage Meter
But at the end of the day here is what matters most I believe.
The QoS works better since the WAN modem is built-in so packets get prioritzed to the ISP not just the WLAN .
So it would appear there are advantages for 3700 buyers looking for a combined solution to seriously look at the DGND3700. Given what I learned here I will be giving one a try myself!
Bob Silver
