Hi all.
I'm looking for some advice on putting together a new stereo music system. I haven't bought such a thing for nearly a decade and so am somewhat behind the curve. Here is my situation in bullet point form:
I have been reading these forums and have learned that transports do not really affect sound quality. Therefore my current thinking is to use my existing (cheap) DVD player and a dedicated DAC to play my CDs. When I feel like it I can plug my laptop into the DAC instead. Here's what I'd like to know:
Thanks in advance to you all.
Also, as a small aside: On these new-fangled DVDa and SACD 5.1 recordings of old albums: Are they worth it (if you have the kit to play them)? I find it hard to believe the original recording of, say, Tommy, can contain the information necessary to create a surround-sound track.
- I own mostly CDs, all of which I have ripped using Apple Lossless.
- I have no interest in the quality of sound accompanying the movies I watch. My TV's speakers are fine for that.
- I want to be able to put music on to play and then wonder around while listening. Being confined to one spot is no good.
- I am no professional and would doubt my own ability to differentiate between a CD-quality recording and a higher bit-rate track. But I've not tried this, so I could be wrong.
- I will be unlikely to spend over $1000 on the whole lot.
- Does my plan make sense?
- What do I need to put between the DAC and the speakers? For example, do people still use integrated amps?
- What is a sensible split of funds between DAC, amp, speakers (and anything else I need)?
